Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
- Yamaha nypex mcx 400
I have a dalton black/lime now with 46/36. Hole 3What hole do you run green in?
With 46/36 on trail setup with 280 hp I ran it in hole 1
Softest
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
This is my old post from last season. Running different turbo kit now.
See n blue
- Dec 10, 2013
- East
- 2017 LTX
How does it feel? That’s a stiff spring but really depends what you’re doing with the sled.I have a dalton black/lime now with 46/36. Hole 3
Dalton white or AC green is usually the go to
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
Feels fast and works great but maybe best for trail and lake riding. Im looking for something with better acceleration for lake/drag race on snowHow does it feel? That’s a stiff spring but really depends what you’re doing with the sled.
See n blue
- Dec 10, 2013
- East
- 2017 LTX
I would run your straight 44 with the green spring in the middle hole.Feels fast and works great but maybe best for trail and lake riding. Im looking for something with better acceleration for lake/drag race on snow
Have your ramps 2- A
2-B
Trailleader
- Feb 9, 2023
- Wausau Wi
- 17 9000 stage 4
I agree with above but would try to run as little spring as possible
I say hole 1 softest
The more angle and less spring the quicker the upshift and that’s what you’re looking for
Don’t need any backshift
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
ok thanks! Is it different green ac springs? Mine is very stiff, so wondering if it wrong spring.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
No issues with a 46/36 or 50/40 and sno pro green at 375 hp trail riding . Biggest issue with that much hp on the trail is traction
Trailleader
- Feb 9, 2023
- Wausau Wi
- 17 9000 stage 4
Drag racing you’re going up though correct? He’s not trail riding and I agree on trail with you
He’s drag racing
Have you tried snow shovels that screw on the stud
Mixing those in on some of the bigger hp machines for snow and trail ridding
What length is the sled also
144 I assume
There’s a trail machine here that’s working well like that and hooks but can’t always use antilag
Set a record at a track here in trail class at 118 in 400 ft
He’s drag racing
144 I assume
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
No issuse with the 46/36 at all, works great
But was looking tips for a clutch setup for drag/lake racing with more acceleration, 200-300m. My sled is 153 inch and setup for trails
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
4 arm STMBig phil
Are you running a 6 arm stm?
customnytromtx69
I’m running a 450hp big turbo mcx kit with 4 arm stm and stock secondary . Running 39/35 helix with black tan spring but I’m still working on getting it dialed in
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
Double check your boost and RPM. Your sled should be mental if it truly has 400+ hp. We have a drag viper that makes 450ish horse and it pulls away from a 300 horse sidewinder at the same rate a 300 horse sidewidner pulls a stock 800cc sled. STM primary with stock secondary, 50/43 helix and purple spring.
I tryed a 50/44 with purple spring in hole 3 (middle hole) in stm secondary clutch but the belt slipped in secondary clutch, It was rubber marks in clutch.
How much extra weight are you running in the TAPP from stock? Plus 2 rollers? You want to put weight on the roller bolts and get some of the weight off the arms. When are you slipping the belt? Let's see the pics of the sheaves. Down low on the sheaves you need more spring or a lower finish on that helix for more high speed belt grab.
- 17K
- 51K
