tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
What model Float is that you got? Is that the standard now?? Looks like an early present!!
yamahaboy701 said:Moto,
Haven't seen you in a while. Have you been riding?
If we had ANY snow I would be....
I need to get with you guys, I know you are skipping the Horns this year, but everywhere else you are going is fairly close to me. I'd like to ride with you guys for a day or two at least...
tapex_07 said:What model Float is that you got? Is that the standard now?? Looks like an early present!!
It's a Float X... it's an added option on the TS skid for 2010... and he exerted a lot of patience to get the first one from us! I certainly hope it was worth the wait!!!
tkuss
Moto, Jan 8th through the 10th we are riding togwotee. Then the 11th and 12th we are riding Island Park.
yamahaboy701
I went with the float X option for a few reasons. I will ride in WI and MI with this sled and if the trails are harsh it should help the ride because not only does it have the reservoir but also adjustable compression and rebound setting.
Laid out the measurements on the rails tonight but did not have a 25/64 bit so I will get one tomorrow, also did not have time to go to the shop and use the jig saw to mod the rails.
yamahaboy701
I made it to the shop tonight to mod the stock rails. It went great and everything lines up perfectly. Assembled everything and then disassembled it so I can have the rails powder coated. I do have a small problem. Were should I mount my ice scratchers? I want to run a few small wheels for the trails so I can't mount them in front so I tried the middle but the rear arm will hit it when I bottom the suspension out.
![DSC01531.jpg](/proxy.php?image=http%3A%2F%2Fi432.photobucket.com%2Falbums%2Fqq50%2Fyamahaboy701%2FNytro%2520MTX%2520Build%2FDSC01531.jpg&hash=886c7f6f68635cf194903e136c61167d)
![DSC01528.jpg](/proxy.php?image=http%3A%2F%2Fi432.photobucket.com%2Falbums%2Fqq50%2Fyamahaboy701%2FNytro%2520MTX%2520Build%2FDSC01528.jpg&hash=9ed5d7f664b267f5b2f236cf8885b123)
![DSC01533.jpg](/proxy.php?image=http%3A%2F%2Fi432.photobucket.com%2Falbums%2Fqq50%2Fyamahaboy701%2FNytro%2520MTX%2520Build%2FDSC01533.jpg&hash=f97a14dec8ca3ac9c4b77e9b2b783880)
tapex_07
- Feb 15, 2009
Wow that looks like a nice set up! Maybe run one set of wheels in the front and one near the tip up..? I personally dont run any wheels, and havent had any problem in the last 4 years.
yamahaboy701
Final had some time today to go pick up my trailer. Its a 2000 pace Aero sport. Will hold three sled but is very very heavy. Truck pulls it great and with the two axles it pulls extremely straight. I got new rims with the trailer and putting them on tonight.
![DSC01536.jpg](/proxy.php?image=http%3A%2F%2Fi432.photobucket.com%2Falbums%2Fqq50%2Fyamahaboy701%2FMy%2520Truck%2FDSC01536.jpg&hash=665e042d136f6d585dc3b0ee3decb4d0)
awsome sled
I know you have probably checked this. I hope your front ohlins resi isnt going to hit the a arm on full compession.
yamahaboy701
Re: awsome sled
Thanks,
I noticed that when I put them on and tested the clearance. Even if I took the rubber stops off the shock shafts I would have 1.5 inches of clearance.![Div20 ;)! ;)!](/styles/default/xenforo/smilies/div20.gif)
srx900 said:I know you have probably checked this. I hope your front ohlins resi isnt going to hit the a arm on full compession.
Thanks,
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
sonds
- Oct 7, 2008
- Golden Valley MN
- ductworksmn.com
- 08 T-Nytro
yamahaboy701 said:Final had some time today to go pick up my trailer. Its a 2000 pace Aero sport. Will hold three sled but is very very heavy. Truck pulls it great and with the two axles it pulls extremely straight. I got new rims with the trailer and putting them on tonight.
Nice trailer. Does it have surge brakes?
sonds said:yamahaboy701 said:Final had some time today to go pick up my trailer. Its a 2000 pace Aero sport. Will hold three sled but is very very heavy. Truck pulls it great and with the two axles it pulls extremely straight. I got new rims with the trailer and putting them on tonight.
What kinda question is that????
![Wut60 ;):D ;):D](/styles/default/xenforo/smilies/wut60.gif)
yamahaboy701
Thanks and no,
It has electric brakes, I just installed my new Tekonsha P3 brake controller which I found out today can be very sensitive.
That reminds me, I should check the adjustment on the brakes when I have the tires off.
yamahaboy701
MotoPsycho said:sonds said:yamahaboy701 said:What kinda question is that????![]()
Wish it did! But hey for $2500 it not bad
![Rockon :Rockon: :Rockon:](/styles/default/xenforo/smilies/rockon.gif)
yamahaboy701 said:MotoPsycho said:sonds said:yamahaboy701 said:What kinda question is that????![]()
Wish it did! But hey for $1500 it not bad![]()
rockin' deal buddy!!
