ghost rider
Suspended
- Nov 13, 2013
- Muskoka, Ontario, Canada
- Rxwarrior
- Muskoka , Ontario
DigitalFusion said:anyone know off hand what the warranty is on these things? I'd kinda like to get them to send me a new bolt just so all the bolts on the skid have the same head size. The replacement I had to pick up has a 17mm head instead of 15mm.
I have a brand new skid. The warrantee is only for one year.
You mentioned earlier in a post that you torqued to 50 lbs which is correct.
Personally I think the grade of all the bolts are less than perfect, so I up graded all my skids bolts to over exceeded the factory specs by one grade point. Plus red loctight and I check the torque before each outing.
stomper
I put a horizontal mark across each bolt head with a jiffy marker so that I can tell with a quick glance if a bolt is spinning or coming loose. I picked that tip up in this forum. I believe it was Kinger that mentioned that tip.
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
- 14 Viper LTX, 10 Turbo Phazer MTX, 08 Phazer, 88 SnoScoot
this thread is like a year old guys!
ghost rider
Suspended
- Nov 13, 2013
- Rxwarrior
- Muskoka , Ontario
DigitalFusion said:this thread is like a year old guys!
problem solved…….maybe i need need reading glasses ….those date stamps are very small….
It might have started to come loose. Mine did the same thing when I had about 200 miles on it, I used nord-lock wedge locking washers,
http://www.nord-lock.com/products/wedge ... roduction/
with loctite tightened at 40ft/lbs, never happened again. I have about 6 or 7 thousand HARD miles on it since then
ghost rider
Suspended
- Nov 13, 2013
- Rxwarrior
- Muskoka , Ontario
guardrail said:It might have started to come loose. Mine did the same thing when I had about 200 miles on it, I used nord-lock wedge locking washers,
i saw your post mentioning nord loc washers….iv'e seen them in automotive applications -why not sleds.
Are they as good as reported.?
Definitely! They use them on jackhammers. I read about them on here somewhere. Since I've used them, I never had a bolt come loose since. They're a little pricey but it's well worth it.
ghost rider
Suspended
- Nov 13, 2013
- Rxwarrior
- Muskoka , Ontario
guardrail said:Definitely! They use them on jackhammers. I read about them on here somewhere. Since I've used them, I never had a bolt come loose since. They're a little pricey but it's well worth it.
Thanks for the tip….gaurdrail. Heh how do you like the Ulmer clutch? I was thinking of up grading.
Initial setup was dead on. Only had to make a slight adjustment when I put the stainless y pipes on. Highly recommend it.
