yank
- Jan 3, 2006
- Cook,MN
- 2005 rs venture
2006 rs rage
1971 elan
Classic track howl...well documented in other threads.
Cause: idlers running over the fiberglass rods in the track lugs (washboard effect). I've pulled all the idlers & the noise/vibration completely disappears. Heavy sled + thinner tracks+ harder idlers=deafening howl.
Fix: Intall an AC "Quiet Track", which AC patented, which is why Yami can't copy it, OR see my fix using studs & washers(search out "yank" & "track howl"). Worked great on my Venture.
Yami needs to find a factory fix for this or they will start losing customers fast!
mdkuni
yank said:Classic track howl...well documented in other threads.
A little effort to read the thread would be appreciated.
This is not a howl. It is a solid vibration, just like running over rumble strips in your car.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Yes the rumble strip sound is what best decribes mine. It seemed ok then just started I actually stopped and look to see what it was. Next hardpack road I found it was much less. So far I am not annoyed but hoping for 700+ miles this week, so I'll update after.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Aaaahhhhhhh that's why I have no track howl or vibrations I guess, I run a AC RipSaw 1.25x136 Quiet Track unstudded
kinger
- Jan 17, 2005
- Clear Lake, IA
I just did another 500 miles on mine and no vibration except on occasion and I think its when the track was eating a big chunk of ice from the tunnel. She is smooth as glass other then the normal slight vibration from the engine.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
powershot1
try shorting limiter strap just to keep the front of the rail off the track clips.
yammiman
I added idler wheels out toward the front of the rails simular to an extra wheel kit - I also run the track on the loose side - pretty much eliminated the problem
