Ryan Gorby
- Oct 24, 2015
- st marys
- 2005 Yamaha Rx1
On hard packed groomed trails my sled darts all over the place sometimes it's kinda scary because it's so unpredictable on what it's going to do . Is there any way to fix this ? Changing skis ? Adjustment anywhere ?
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 18 Sidewinder (Wifes)
12 Nytro XTX (mine)
09Apex GT (?)
02 Viper (grass dragger)
Woodys Doolly Carbides
BigDogrx1
- Dec 2, 2014
- SOO (UP) MI
- 2003 rx1
Toe out skis 1/8" and bergstrom triples with shims will fix it also.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
doolys take care of darting but will push in corners. Snowtrackers are what I suggest. I sell both. Have some used doolies here too.
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
X 2, hands down the best there is for darting/tracking without push! Set toe to 0 and enjoy the most settled sled you have ever ridden!doolys take care of darting but will push in corners. Snowtrackers are what I suggest. I sell both. Have some used doolies here too.
superfan75
- Sep 12, 2013
- West Topsham Vermont
- RX Warrior
Also make sure you don't have too much ski pressure and make sure there isn't too much play in the front end. The a arm bushings wear out, also there are ball joints and steering stem bushings. A good starting point is set the ski shock preload so that the a arms are parallel to the ground. Ski alignment is also important and then if all is good then you can play with limiter strap on the front arm in the rear suspension. If you lengthen it, it will help take some weight off the skis. The trick is getting the right amount of ski pressure so the sled turns good, but isn't so light in the front it gets tippy and pushes through the corners. Only make one adjustment at a time so you know what did what. Also shimming the skis helps too. Good luck getting the darting to go away.
tedgoesfast
i have a 2005 rx i put jagged edge runners and easy steers on skies then use a quarter inch rubber shim under back of ski rubber fixed it i can drive one hand
Ryan Gorby
- Oct 24, 2015
- st marys
- 2005 Yamaha Rx1
Ok thanks guys
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
x2
Ryan, I just replaced all front end bushings and tie rod ends in an '04 Warrior. You wouldn't believe how much A-arm slop and handlebar wiggle is now gone!
At least check all these things, in addition to all the other advice mentioned above!
Ryan Gorby
- Oct 24, 2015
- st marys
- 2005 Yamaha Rx1
How much for the snowtrackers?doolys take care of darting but will push in corners. Snowtrackers are what I suggest. I sell both. Have some used doolies here too.
kviper
- Nov 7, 2003
- Oakfield WI
Last pair I bought were $220 ish. They will generally last about as long as two set's of others and will out perform anything else out there in my opinion. As mentioned above, with anything all wear points should be tight for best results!
Purplecoffin
Lots of good suggestions here. First thing for sure is to set toe out and shim. Decent chance this will make a dramatic difference. I don't use anything special for carbide and I have almost 0 darting. I do not have stock skis though.
Ryan Gorby
- Oct 24, 2015
- st marys
- 2005 Yamaha Rx1
Ok what part do you shim and what kind of skis do you have ?Lots of good suggestions here. First thing for sure is to set toe out and shim. Decent chance this will make a dramatic difference. I don't use anything special for carbide and I have almost 0 darting. I do not have stock skis though.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Doolies on all three of my sleds, drives like on rails. Simplest fix out there!
kviper
- Nov 7, 2003
- Oakfield WI
Shimming loads the rear of the ski lifting the front. It also causes harder steering or at least it has on every one I have ridden.
