RB Racing
- May 15, 2016
- Winnipeg
- 2013 Nytro xtx 1.75
- Winnipeg, Canada
Is this a year specific ball joint? Aftermarket lists 07-08 and 10-14 ?
Will these ball joints work. This is my first sled trying to get it ready for riding. Thanks.
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Go here and put in your year and model. You can go back and forth from year to year and see what has changed and get the proper parts!!
You don't have to buy from them,but I have had good luck as long as I get to the minimum for free shipping otherwise they get you on shipping (beware).
http://www.procaliber.com/oemparts/#/c/yamaha_snowmobile/parts
Good luck
Pete
Good luck
Pete
herndonp
- Nov 28, 2012
- Freedom,NH
By the way there is a left hand and a right hand ball joint make sure you order the right one.
Pete
Pete
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Hey Pete
The lower ball joint on the a arms - left and right are identical, same as the upper joint and stering ball joint
They may be identified with a different part code but are the same part.
Ms
Ms
herndonp
- Nov 28, 2012
- Freedom,NH
That seems stupid. Why would they do that?
Pete
Pete
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I think starting in 2010 the nytro ball joints are a 3 piece ball joint. There are 2 inserts that press into the ball. You can put a 10+ in an 08-09 but you need to order the inserts as well.
The after market ones I have access to are the 10+ style. I can provide pics if more clarification is needed.
RB Racing
- May 15, 2016
- Winnipeg
- Winnipeg, Canada
Sure if you could post some pics that would be great, my a-arms are in getting powder coated now.
I ended up ordering the 2010 after market ball joints hoping they will work.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Pete
I have come across numerous parts, especially in the skid that are symmetrical but have separate codes. Doesn't make sense to me and seems to add more layers of work for the oem.
Who knows....
Ms
Beenba
- Feb 16, 2011
- 2009 Nytro XTX
OP where did you get the lower BJ's from? My 09 XTX has about 15,000km on it now, and I plan to replace uppers and lowers this fall - they've never been done.
herndonp
- Nov 28, 2012
- Freedom,NH
They are just trying to confuse us!!I have come across numerous parts, especially in the skid that are symmetrical but have separate codes. Doesn't make sense to me and seems to add more layers of work for the oem.
Who knows....
Ms
Pete
RB Racing
- May 15, 2016
- Winnipeg
- Winnipeg, Canada
royal distributing they have upper and lower ball joints. Do your a-arm bushings while your at it and check the spindle bushings.OP where did you get the lower BJ's from? My 09 XTX has about 15,000km on it now, and I plan to replace uppers and lowers this fall - they've never been done.
RB Racing
- May 15, 2016
- Winnipeg
- Winnipeg, Canada
Ball joint just showed up looks like a match.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Ball joint just showed up looks like a match.![]()
Is the inside diameter correct?
- 10K
