Joe williams
- Dec 22, 2020
- Wisconsin
- 09 Phaxer and 14 sr viper ltx
I bought a 09 phazer with 1700 miles. It appears that it does not want to go into reverse or drive unless I rock the sled or pickup the back end. I have been reading a lot on the problem and it seems to be a common issue. The fix seems to add a shim to the secondary clutch. I am new to sleds and trying to figure where the shim goes. Does the shims go behind the clutch or in front of the clutch? Or do I need to take the clutch apart and put the shims on the inside? Everything I read is that it is a 15 minute fix but nothing says exactly where to put the shims. TIA
Take it apart and put shim inside. You want the belt to be slightly lower in the sheaves when at a stand still.I bought a 09 phazer with 1700 miles. It appears that it does not want to go into reverse or drive unless I rock the sled or pickup the back end. I have been reading a lot on the problem and it seems to be a common issue. The fix seems to add a shim to the secondary clutch. I am new to sleds and trying to figure where the shim goes. Does the shims go behind the clutch or in front of the clutch? Or do I need to take the clutch apart and put the shims on the inside? Everything I read is that it is a 15 minute fix but nothing says exactly where to put the shims. TIA
Joe williams
- Dec 22, 2020
- Wisconsin
Do I need a compression tool to take the clutch apart?Take it apart and put shim inside. You want the belt to be slightly lower in the sheaves when at a stand still.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
No you can do it bye hand
Number six in this picture.
Remember to give the cam a twist before shoving it into the sheave half. That is something most get wrong that haven't done this before.
2008 Yamaha PHAZER RTX (PZ50RTXL) Secondary Sheave | CyclePartsNationNumber six in this picture.
[URL='https://www.cyclepartsnation.com/oemparts/a/yam/5003c4e8f8700212fc842634/secondary-sheave']2008 Yamaha PHAZER RTX (PZ50RTXL) Secondary Sheave | CyclePartsNation[/URL]Do I need a compression tool to take the clutch apart?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I have found that it helps if you adjust the drive chain on the "loose" side. Manual says finger tight but I would turn the adjusting bolt until it barely made contact with the chain and back off 1/4 turn. And adjust the idle to the low end of the spec (1400RPM IIRC). Be sure you use the updated belt as per the bulletin for previous years.
https://ty4stroke.com/threads/diffe...8gk-belts-reverse-update.156607/#post-1474686
Joe williams
- Dec 22, 2020
- Wisconsin
Thanks everyone. I am waiting for the shims to come in and will give it a shot.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
What's your "warmed up" Idle RPM, anything over 1900 rpm makes it hard to get into reverse. No amount of jumping, rocking, bouncing will get mine into reverse until it's warmed up and the RPM drops.
Joe williams
- Dec 22, 2020
- Wisconsin
Mine are at 1400 rpm when warmed up.What's your "warmed up" Idle RPM, anything over 1900 rpm makes it hard to get into reverse. No amount of jumping, rocking, bouncing will get mine into reverse until it's warmed up and the RPM drops.
Should only have to add one.Thanks everyone. I am waiting for the shims to come in and will give it a shot.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Shouldn't have to add any since it's an 09 and already updated. The belt might sit too low with another shim.
Did you try a new belt?
Joe williams
- Dec 22, 2020
- Wisconsin
So the 09 has the update? IShouldn't have to add any since it's an 09 and already updated. The belt might sit too low with another shim.
Have not tried a new belt. It has the 8GK belt on it and it looks pretty new.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Yep. The TSB was for 07 and 08. By 09, they were applying it to all of them from the factory. Confirmed by the fact that you have the 8GK belt.
If the sled has only 1700 miles, you likely still have the original belt, which might be a little dry and stiff after 11 years. I'd try a new one.
Sometimes machines don't get updates done.
