4bangpower
Allen,
Have you played with the stock 24/38 gearing on the new '10 Vector GT's to see if there would be a benefit to making a change? Or would you leave it as is and simply add the engine performance kit.
Also, would you recommend 120 or 144 studs to accompany the performance kit? Thanks!
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I haven't had a chance to change the gearing just yet. I intend to gear down 1 tooth on the top gear this week and test it out to see if we can. 120 studs should be just right on the 121 model.
pistol
Any news on the gear change results?
- Apr 17, 2003
- Menno, SD
- Menno, SD
In process of studding the track still!
pistol
well stop messing around and get on it man....
- Apr 17, 2003
- Menno, SD
- Menno, SD
Geared down to 22/39, but raining out so no testing as of yet!
pistol
Any results for not only the gearing but also the additional air inlets etc. 150hp kit yet?
- Apr 17, 2003
- Menno, SD
- Menno, SD
I will not have much time for testing. We had an unfortunate accident with my father on Monday morning and I will struggle for a while trying to keep up with the work flow by myself. All of our shop testing has been put on hold for now.
http://www.ty4stroke.com/viewtopic.php?t=84134
pistol
Yikes!!! We all wish you and your family the best.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Sorry to hear about your father...I wish him a speedy recovery!!!...
- 7K
- 36K
