saleen347
- Dec 26, 2014
- 2014 SR Viper RTX
My viper has developed a lot of play in the handle bars. They move a lot before the skis even move. When it's sitting you can turn the bars a few inches before there is any resistance or the skis move. Seems to be in the bottom part of steering. Anyone else had this problem?
stingray719
Yes, on the right side of the sled where the tie rods go in....pull the rubber down and tighten the nut on the bottom of the steering shaft. Put a drop or two of locktite on it. This is a known Cat chassis thing, if steering gets loose check this right away.
Please report back and let us know if this was your issue.
saleen347
- Dec 26, 2014
- 2014 SR Viper RTX
Thanks, I'll get it on the lift tomorrow and check it out. Thanks for the quick response.
Also found a lot of play in the pivot down there. Small 10mm bolt between the a arm bolts under that rubber cover at front. Do NOT tighten it. That one just holds two big washers on. If you tighten it you are just crushing the washers. There needs to be a spacer in there like a a arm but there isn't. Plan to address this in spring.
Another area is a lot of play is steering stem block. I highly recommend the billet one. Tightening those bolts will help that short term.
saleen347
- Dec 26, 2014
- 2014 SR Viper RTX
Who makes the billet block? Got a link?
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX
2018 High Country 9000
2001 SRX 700
Mine did the same thing 3 times in 300km. It was the nut under the end of the steering column that loosened. It need a 17mm wrench. I removed the air box to access. Last time I removed it and put blue loctite on it. No problem since and did more than 700km.
http://oftracing.com/OnlineStore15/index.php?main_page=index&cPath=34
Mine did the same thing 3 times in 300km. It was the nut loosing under the end of the steering column. 17mm wrench. I removed the air box to access. Last time I removed it and put blue loctite on it. No problem since and did more than 700km.
I have seen this also. Thought they had that fixed. Will check mine also.
stingray719
Steve you have that bulletin for the 2014 Cats to check this same thing? I too had hoped they had fixed this
Adams574
- Jul 2, 2014
- 2015 Viper LE Mpi turbo 162
2012 Nytro MTX 153
2009 Nytro XTX 144
Previous
2009 Summit 800
2008 Summit X 800
2007 Apex warrior
2007 Summit 800
2006 Summit 600
2006 MXZ Renagade 600
2004 RX-1 Mountian
2002 RMK 800
1996 ZR 580
1988 Cougar 500
1985 kitty cat
Good timing. After just 200miles my steering has at lease two inches of play before any movement. It even seemed to lock or bind up when at full turn. I will check the above mentioned, thanks
stingray719
Cannondale27, is this a candidate for a sticky?
tumpline
- Jan 23, 2014
- Mississauga
- 2002 sxviper
2014 xtx viper
Yes check the bolt at bottom of steering shaft, while on a long trip last year mine started to loosen, at end of trip I had almost 6 inches of slack, made for some intense riding, make sure you put locktight on nut after you tighten.
Done. Yes definitly.
I saw that and looked at mine. I thought the steel plate they added was in there already. Will look again.Steve you have that bulletin for the 2014 Cats to check this same thing? I too had hoped they had fixed this
saleen347
- Dec 26, 2014
- 2014 SR Viper RTX
Ok, my nut had about 4 threads left before it would've fallen off. Removed the nut, applied red locktite and reinstalled. Hope that fixes it. To gain access just remove all the push pins holding the rubber boot to the sled. Use a 17mm socket with small extension to remove nut. Thanks everyone.
