Johnlyons02091969
- Feb 16, 2015
- 2003 yamaha rx-1 er
When I start my 2003 rx1 the starter starts but just make a spinning sound like it's not engaging and then after a alot of try's it finally engages and starts the engine. Does anyone think it's the starter or maybe the reduction gears
tproteau
- Sep 28, 2014
- Wpg Manitoba
- 2003 Yamaha Rx-1 LE Liquid Silver
1998 Polaris XC 700
2007 Ski-Doo MXZ Adrenaline 800 HO
starter clutch... mine did the same thing after I got it
Johnlyons02091969
- Feb 16, 2015
Is it a pain to change outstarter clutch... mine did the same thing after I got it
tproteau
- Sep 28, 2014
- Wpg Manitoba
1998 Polaris XC 700
The oil tank has to come off, then the crank case cover comes off, then you have to use a puller to get the magneto rotor off then the starter clutch assembly can be replaced.
the job wasn't really that difficult just need the right tools and patience. You'll need a 6 inch puller to take the magneto rotor off, and you'll want to order a new crankcase cover gasket when you change it, mine was ripped at the bottom when I removed my cover.
tproteau
- Sep 28, 2014
- Wpg Manitoba
1998 Polaris XC 700
also wanted to ask, when you turn your key does it kick sometimes and then spin then kick again over and over?
Johnlyons02091969
- Feb 16, 2015
Yes it kicks when I turn the key and then spins and it keeps doing the same thing every time I turn the key just not enough turns to start the engine
tproteau
- Sep 28, 2014
- Wpg Manitoba
1998 Polaris XC 700
starter clutch then. replace and no more headaches simple job takes less then two hours to perform. change your oil while you're in there.
Johnlyons02091969
- Feb 16, 2015
Ok thanks for the help
tproteau
- Sep 28, 2014
- Wpg Manitoba
1998 Polaris XC 700
if you have any more questions on changing it out just let me know.
- 10K
