markvv1
- Nov 10, 2011
- Milverton, Ontario
- 2021 Yamaha Sidewinder xtx se, 2007 Yamaha Phazer Gt (144), 2006 Yamaha Apex rtx.
Sled has been randomly not starting. Now wont start at all. I have replaced battery, fuel pump relay replaced, did the ground update and replaced starter relay. I have done the diag on the gauge and the fuel system says 0v. The sled cranks just no fuel. Ignition switch maybe? All fuses are good.
turbogts22
- Jan 16, 2021
- Spooner, Wisconsin
- Two 2010 Phazer GT's
So diagnostic mode # 9 is showing 0 volts? I wonder if a fuse holder is corroded or a relay connector.
markvv1
- Nov 10, 2011
Yes thats right and theres no power at the pump. The Starter relay and fuel relay I just replaced this morning battery is 2 days old and fully charged.
turbogts22
- Jan 16, 2021
I'm thinking either a missed ground connection or no power flow through a fuse, possible corrosion related.
markvv1
- Nov 10, 2011
Ok going to keep looking at all the connections.
markvv1
- Nov 10, 2011
turbogts22
- Jan 16, 2021
Hmmm, that's just out of focus enough for me to not recognize it. But look around and you might discover what's going on. You might be close.
markvv1
- Nov 10, 2011
Now after going through it all again it wont crank now either. Battery is fulling charged.
have you found the ground blocks in the harness and verified that they are good?
markvv1
- Nov 10, 2011
Yes just did the ground block update yesterday since it wasn't done. Bought this sled 4 years ago has been nothing but a pain.
markvv1
- Nov 10, 2011
I'm thinking I might have put the wires on the starter solenoid on backwards. Will check this afternoon when I get home. I took pictures of everything I did and it looks like they are backwards.
markvv1
- Nov 10, 2011
So I had the postive and the negative wires somehow reversed on the starter relay and now have fuel system running, but it now wont crank unless a jump the connection. Did I fry the relay and now need another new one?
turbogts22
- Jan 16, 2021
I think there might still be something switched around with the wires. An incandescent 12v test light would be really helpful with pinpointing some of these issues.
no. it sounds like you got an rs starter relay. you have to take the wires out of the plug and reverse/move them so they are in the same place as your origonal one. common occurance.So I had the postive and the negative wires somehow reversed on the starter relay and now have fuel system running, but it now wont crank unless a jump the connection. Did I fry the relay and now need another new one?
markvv1
- Nov 10, 2011
So you are saying the wires that plug into the top of the relay need to be switched also not just the battery and starter wires.
