Canuck Sledhead
"All' they have to do is transfer more weight from the front to mid sled.
I ride the 2006 Apex (Atak) which has not changed much. It's either don't mess with a good thing, or change it once you know that change is for the better.
I suspect that they will change it for next year.
zoomzoom
I don't see yamaha coming out with a sled that has a supercharger or turbo unles it can still run 87 octane. There are a lot of trail riders out there (myself include) that ride in northern canada where u cant guarantee you'll come across a pump with 91 octane.
I'am with zoomzoom on that.
japex
so you can't just have low comp pistons and still run 87?
SharkAttak
i'm hoping them come out with something new, but you may be right since the economy isn't that swift
copo427ss
xracer said:If you look up 06 r1 (right around when they would be designing a new sled) its rated at 175- 183hp at 12500 rpm on 91 octane,minus sum compression to run on 87 octane, would be 170-175 hp![]()
the 06 r1 motor is still the 5 valve motor in our sleds. 07-08 are the new 4 valve head engines. just found my title to my 07 r1 today. the hp sae printed on the title is 176.1 hp
