rightarm
G Force
Here are some pictures showing particularities of the Lamtrac/G-Force One transmission.
The snowmobile has two separate transmissions. The primary is a normal sled transmission with pulleys, a belt and a chain case.
When the sled approaches top speed, the driver engages the direct drive transmission. The direct drive has a gear ratio about 10% faster than the primary transmission.
The direct drive purpose is mainly for reliability issues as the sled will be maxed for about 3 miles. There also should be less mechanical friction/slippage/worries than a conventional belt system. The same group of people that have developed the "Yamahacharger" forced air induction for your production sled.
xracer
The motor testing they already have through years testing race bikes, they would only have money invested sled set up ,and lighter parts for the new sled, the apex only really needs an improvment in ski pressure & weight right now
radianguy
- Jan 1, 2007
Sorry, a traditional snowmobile clutch would not hold up!rightarm said:radianguy said:How long do you think a snowmobile clutch will hold up to 16,000 RPM?? Not gonna happen!yamahahaha said:i dont the apex or nytro will leave the line up either(like someone else said) they are still selling well (around here anyway) i could see yamaha up dating the phazer tho... the r6 motor in it would be awesome!!!!!!!!!! it would be a 600 and be in the 120 hp line-up. and a 4 stroke oviously, and it would rev to 16000/18000!!!!!!!!!!!!! i would probly buy that sled
the G-force guys use a hydraulic primary system as there primary runs off the crank, spiningn the motor and clutches to full song.So it is happening.
All of this new technology comes with a price. If this were to find it's way to Yamaha you could expect the price to increase alot, just look at how the price of the Vector soared when they put the FI motor in it. JMO!
xracer
All new from the ground up, body style halfway between apex & nitro
Now did we get the 04-05 5 valve or the newer 4 valve r1 motor ?
WANN4STROKE
- Feb 26, 2007
- Anchorage, Ak.
- 2009 Viking
2006 ApxMtn-sold
2001 MtnMax-sold
1998 VMAX 500-totalled
I'm hearing power steering and rider forward-more like the Nytro.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Check my post on the CDN Blog... Apparently this new sled (he says it's a stocker) is faster then the then the Yamahacharged Apex..... Not by much, but it was.... Looks to be runner and should be pushing out a good number for hp if this is true...
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
SledFreak said:Check my post on the CDN Blog... Apparently this new sled (he says it's a stocker) is faster then the then the Yamahacharged Apex..... Not by much, but it was.... Looks to be runner and should be pushing out a good number for hp if this is true...
where did he say all this?.....this sounds AWESOME!
Dan
SledFreak
- Feb 7, 2005
- Ontario. Canada
xracer
It would be a better sled all around (speed & handling) or he wouldn't have taken the (new) stock sled out against yamacharger apex on supertraxs ride day
SledFreak
- Feb 7, 2005
- Ontario. Canada
I agree and he would not have raced a stock Apex against a yamahacharger or he would have mentioned it...xracer said:It would be a better sled all around (speed & handling) or he wouldn't have taken the stock sled out against yamacharger apex on supertraxs ride day
xracer
If you look up 06 r1 (right around when they would be designing a new sled) its rated at 175- 183hp at 12500 rpm on 91 octane,minus sum compression to run on 87 octane, would be 170-175 hp
7 skulls
I read that yamablog post too... The "it" is a yamacharger against a stock apex, not the new sled. IMO
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
7 skulls said:I read that yamablog post too... The "it" is a yamacharger against a stock apex, not the new sled. IMO
I agree......since he talks about posting the photos or video of it,which he cannot do of the new sled.
dan
SledFreak
- Feb 7, 2005
- Ontario. Canada
He can in 3-4 weeks.....
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Feb 2nd we will all know....
but my guess is we will have more tidbits before then....check out the blogs page for latest.
Dan
Dan
