LEE337
That looks awesome! Nice build!
give me your opinion
The track seems to be a tad long. I just ordered some 9" wheels I am hoping that gets me a bit mor adjustment out of the track.
The track extends past the tunnel about 2". Its not to terrible noticeable but it bothers me a bit. I know skins makes a extentsion kit but installing it I think will be a real pain with my aftermarket bumper.
What do you guys think? Does the sled look goofy the way it is now????
mysledblows
- Jan 23, 2007
- Central MN
- Sidewinder, mcx phazer, phazer, apex
- Jenkins, MN
Personally I prefer the look of the shorter tunnel. Your flap isn't going to be very happy though
I trimmed a couple inches off it. I thought about making a bracket to point it out a ways. Haha. Its probably still gonna get tore up tho
Hey guys question. With my modified cooling system is like to be able to monitor how hot it is getting. I found a gauge that will fit just perfectly under my boost and AFR gauge.
My question where should the probe bbe placed?
Sportsterdanne
It looks like it but i cant really see it on the pic. But did you mount larger wheels in the stock location ?
Yes stock rmk skid has 7.5" wheels. I put 9" on the stock axle
Sportsterdanne
Does that work ok? Dont you need a offset rear axle ?
It worked fine for me? Went right it. I would assume you would need enough track like I had to be able to fit them in. Otherwise it would be to tight.
What do you mean by offset axle?
OK I just looked them up. They basically just lift the wheel up so the rail is back on the ground. I guess I didn't realize it was a big deal but I can see why this could become an issue. I think I am going to start looking for an axle that will fit my wheel.
Nikolai
If you don't run an offset axle, at least run three wheels. Sled looks good btw.
I just found an axle that will work for me. And thanks
Anyone have an idea where a inline coolant temp probe should be installed at?
- 40K
