![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
Lets get some feedback on this thread from those who found solutions and I will put it in Facts Sticky. Its a scary thing to happen.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
I've read on here were other have had to do the same thing after a roll-over. For some reason disconnecting the battery, turn the key on and off, and reconnecting the battery resets the computer.
ArcticRider
- Nov 19, 2018
- Above the Arctic Circle, Alaska
- 2016 Yamaha Viper STX-DX 146
2021 Vk 540
Thanks for the reaponses, my breather box was spitting out oil two seasons ago and a buddy of mine fixed it, honestly, i dont know exactly how, i know he did something to keep the “ball” from opening and dumping oil. My coolant temp was good, if it happens again ill check the radiator for snow too.Also I may be wrong but I believe the same red light goes on at a overheat. If radiator is full of snow or ice and the snow is sticky and built up on exchanger the sled will overheat and go into a shutdown mode eventually(Red light on Steady). Reversing the fan makes this happen much sooner but I have had it go into the limited power mode(Red light flashing) even with fan going the right way when both were plugged full of snow/slush.
ArcticRider
- Nov 19, 2018
2021 Vk 540
When i got back and disconnected the battery it worked, im just hoping there isn’t some underlying problem.I've read on here were other have had to do the same thing after a roll-over. For some reason disconnecting the battery, turn the key on and off, and reconnecting the battery resets the computer.
I dont think so. I think its just a Defective Flash. Get the new flash asap. Its alot better.When i got back and disconnected the battery it worked, im just hoping there isn’t some underlying problem.
ArcticRider
- Nov 19, 2018
2021 Vk 540
Well at least thats good to know. I’ve read about flashes in this forum, but i have no clue what that is. There are no dealers within 700 miles which is two flights and $3,000 round trip to ship my machine. Is it something i can do or something that a dealer does? If i can do it is there some info you could share with me on how to do it?I dont think so. I think its just a Defective Flash. Get the new flash asap. Its alot better.
I am afraid the flash is only done by a dealer. However it is internet based which you obviously have. A dealer armed with the YDS tool could come to you and do the job in 10 minutes. A good meal offer I bet would go a long way convincing a tech to do it. Sorry it's not simpler.Well at least thats good to know. I’ve read about flashes in this forum, but i have no clue what that is. There are no dealers within 700 miles which is two flights and $3,000 round trip to ship my machine. Is it something i can do or something that a dealer does? If i can do it is there some info you could share with me on how to do it?
ArcticRider
- Nov 19, 2018
2021 Vk 540
Yeah thats too bad, i live so remotely that its very expensive to do anything.I am afraid the flash is only done by a dealer. However it is internet based which you obviously have. A dealer armed with the YDS tool could come to you and do the job in 10 minutes. A good meal offer I bet would go a long way convincing a tech to do it. Sorry it's not simpler.
Norse
- Jan 1, 2019
- Sápmi
- Norway
- 2013 Arctic Cat M1100 HCR 162"
Boondocker turbo 250HP(sold)
2016 Yamaha SR Viper MTX LE 162"
MCXpress 270HP, lots of mods (sold)
2021 Arctic Cat M8000 Hardcore Alpha 155"
N/A (sold)
2023 Yamaha SW MTX LE 153"
M&M Racing 270HP, Elevate, lots of mods
My sled has always done this, every flash. It happens only when I've been riding hard or the coolant temp is high when I shut down. I believe the solution is to ride easy the last few minutes before you shut it off, making sure that coolant temp is actually getting lower. That way I've never seen my light come on at shutdown, either key or killswitch.
