blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
May is 16.5 I believe. Pop open the belt side cover and take a peak at the valve cover area, 1/2 circle rubber plugs = old engine, 1/2 circle casting marks = new engine.How do you know what is a 16 or 16.5? I have a 16 RTX SE I just picked up in March and it says it was manufactured in May of 15. Is there a clear cutoff date between the 16's and 16.5's?
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
Thanks, not going to ever put a turbo on it, just interested to know which motor it has in it.May is 16.5 I believe. Pop open the belt side cover and take a peak at the valve cover area, 1/2 circle rubber plugs = old engine, 1/2 circle casting marks = new engine.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
The easiest way is to look at the valve cover area of the engine. In the Viper forum under frequently asked question, under new sled inspection 2016.5 late build engine changes there are pictures from cannondale 27
DennyTuna
- Jan 28, 2017
- Ohio
97 SX Vmax 600
I have the new motor in my 16, it has the 1/2 circle casting. Not ever putting a turbo on it just wanted to know for future reference. Reading a lot about the new motor it sounds like its good as long as you don't put a turbo on it. I'm ok with that! That's why I have a sidewinder.May is 16.5 I believe. Pop open the belt side cover and take a peak at the valve cover area, 1/2 circle rubber plugs = old engine, 1/2 circle casting marks = new engine.
hognit09
- Mar 7, 2010
- beaver dam, wi.
- 2016 viper ltx le,2016 viper ltx dx
Just spoke with evolution powersports and they said with the ecu reflash it will be pushing 9800 rpm's. they haven't seen any problems with this in the 16.5 motor. what do you think?Or over rev it.
I think mine is clutched for about 9100rpm and have yet to see anyone document any better speeds than I have gotten. 9800 is a lot more rpm. I can see having the rev limit there but not the clutching. Just for those miraculous perfect conditions or some freak track spin off the line. If new motor with weak rods. No way I would chance it.Just spoke with evolution powersports and they said with the ecu reflash it will be pushing 9800 rpm's. they haven't seen any problems with this in the 16.5 motor. what do you think?
hognit09
- Mar 7, 2010
- beaver dam, wi.
Mine is the newer motor unfortunately, but makes you wonder if another 3-400 rpms is gonna hurt anything, being that you don’t have the internal pressure like a turbo would
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
I don’t think a few hundred overstock iscan an issue but at 9800 you are around 1000 over stock and that might be OK for a rev limit but kinda high for sustained use if you actually clutched to run at 9800.
Right. I have heard them revving that high and although cool sounding as heck not worth risk.I don’t think a few hundred overstock iscan an issue but at 9800 you are around 1000 over stock and that might be OK for a rev limit but kinda high for sustained use if you actually clutched to run at 9800.
Ontarioviperxtx
- Oct 2, 2016
- Northern Ontario
- 2018 Sidewinder xtx
16 viper xtx se SOLD
08 nytro rtx SOLD
- Kirkland Lake
So if I have the bad rods and now want more power what is my best option?? Change rods and install a turbo or just sell and go to a sidewinder???
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
SW would be cheaper overall. Depends on how much power and speed you need.So if I have the bad rods and now want more power what is my best option?? Change rods and install a turbo or just sell and go to a sidewinder???
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Cut your losses now. Save yourself a BUNCH of grief. And go WINDER. Never understood why people torment themselves into thinking they can build the lesser sled into the greater sled, that is already been developed and designed JUST as what they hope to acheiveSo if I have the bad rods and now want more power what is my best option?? Change rods and install a turbo or just sell and go to a sidewinder???
ishpeming fan
- Feb 5, 2017
- Bristol WI.
- 2019 ZR RR 8000
Go winder if you want more speed. You will have better resale value and a sled with a factory warranty all set and ready to rock!
