Robafly
- Dec 19, 2017
- Sudbury
- 2016 Sr viper rtx
Was on on my sled the other day and I was having issues with my ISC fuse blowing. After some research and investigating I found the culprit! Lol! Two wires from the small black box above the oil tank. It rattles when you turn your ignition on. Must be for the fuel pump pressure or primer. Anyway these two wires were touching and blowing the fuse. Bunch of codes were popping up and the reverse beeper would go. Figured I'd share in case someone else runs into this issue. I will try to attach pics. As soon as I figure out how to upload them lol!!!
Robafly
- Dec 19, 2017
- Sudbury
- 2016 Sr viper rtx
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
that's not factory installed.
Robafly
- Dec 19, 2017
- Sudbury
- 2016 Sr viper rtx
2016 rtx with mpi kitthat's not factory installed.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
That's a poorly wired valve. Good thing you found the problem before it left you stranded out on Wanapitei. It could have been a long cold walk to Rocky's
- 25K
