whitty915
I have a 2016 XTX-SE, absolutely love it on groomed trail, but once you hit any un-groomed trail with 1 foot + moguls, the rear end is awful. Has anyone installed the Hygear Pro Linkage kit? Does it fix the issue? How do you like it?
thanks!
thanks!
birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
I installed the linkage kit and Hygear Dual Pressure chamber on the rear Float 3 a week ago on my '15 XTX.
To be honest, not sure what to think, yet. That said, didn't get too much seat time on it after I put on the kit and I'm afraid I have a leak on the Dual Pressure chamber (once I have put air in the main chamber I can't get any pressure reading on the pump from the dual chamber...)
I've seen only good reviews of the kit on this site and that's why I bought it, and from what I've read it's suppose to help in the smaller bumps.
Is your XTX SE having the Float Evol in the rear?
As you, I feel the rear end really comes alive in the bigger woops at speed, it seems to bounce around quite a lot. Without being a suspension expert to me it feels like the rebound is too fast (or maybe too much air pressure in the Float??)
Birkebeiner
Birkebeiner
butches
- Jan 4, 2008
- McHenry, IL
- 2015 X-TX-SE MPI Turbo 180
2017 L-TX-LE Sidewinder
Hurricane Tuned 225/240/270
Thunder Clutching
12,000 miles as of 2/8/2022
2015 XTX SE MPI 180 turbo with pro linkage and dual pressure many miles on forest roads with those bumps and works great no issues and is a great groomed trail suspension also
whitty915
My XTX just has the Fox 3, no Evol.
Yes at higher speeds over the big bumps, the rear end is bouncing up and down like crazy, wont stay on the ground at all.
thanks for the input, still trying to decide if i want to do the kit...
whitty915
Butches, so you could tell a big difference after installing the pro linkage kit? Did you ride the XTX with the stock suspension and notice the same thing with the rear end just getting thrown all over the place?
butches
- Jan 4, 2008
- McHenry, IL
Thunder Clutching
whitty I had it installed by the dealer when it was new had no seat time on stock set up went that set up as many on here recommended it
PS-RagE
- Mar 7, 2016
- Northern Ontario
- 2015 SRV XTX
Mine just arrived along with a full Axis suspension. Going to install it all next week but won't be able to ride again this season.
It is night and day over the stock XTX in all aspects.. the only think you loose is some weight transfer.
SRXracer
So i've been kicking around this whole ltx vs xtx thing the last couple weeks. Currently on an ltx se, but am spending more and more time off trail which is why I was considering the xtx. If everyone is buying the XTX and then putting a linkage on it, why not just buy the ltx instead? Is there an advantage of the xtx with the hygear - does it transfer less than before the linkage, but still way more than ltx?
birkebeiner
- Jul 27, 2009
- Norway
- Norway
thanks!
Maybe this will help?
SRXracer
@MrSled , or others, can you shed some light on this for me? This is probably the biggest thing that is giving me heartburn over which SW to potentially snowcheck. Thanks!
Thats the same issue I had... but I am sticking with the LTX-LE and going to give these new shocks a good shake.
SRXracer
U mean XTX? I thought that is what you were on - or are you switching to the LTX?but I am sticking with the LTX-LE
I am selling my Viper XTX, and I still have a Viper LTX Turbo with a custom XTX-137 skid I made and my new SideWinder will be an LTX-LE
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Because the XTX is 141" track vs the LTX's 137". And the XTX has an uncoupled skid, which is suppose to be better for off trail riding. However, the design of the uncoupled skid of the XTX is that it's a falling rate suspension travel. Watch the above video where Hygear explains the issue with it. The linkage kit fixes this issue.
