Gman25
- Dec 11, 2019
- ottawa
- 2018 sidewinder ltx
1999 srx 70
1993 vmax 750
Hi Guys
Just bought a used 2018 ltx le with 9500kms Sled was clean and well maintained.
Decided to open it up starting with chaincase and lucky I did.
1 of the two tapered screws in roller had fallen out and I presumed got ground to dust.
Is there a updated tensioner or just order a new one and weld screws? Whay a crappy design for a high horsepower sled. Always owned Yamaha and so far I cant say im too impressed with the yamacat.
Anyways any help would be great, I am also considering changing drive shaft brgs and jackshaft bearings as I figure its good preventive maintenance. What brand bearings you guys prefer for this job
thx Geoff
thx Geoff
Just get a new screw and weld the head a little. Also inspect the top gear bushing, it should still have the coating on it. Don't run the chain to tight and put 16 oz of oil in it.Hi Guys
thx Geoff
Gman25
- Dec 11, 2019
- ottawa
1999 srx 70
1993 vmax 750
Ok is that what you guys are running 16 oz? My dealer told me 8.5 glad I asked/posted on hereJust get a new screw and weld the head a little. Also inspect the top gear bushing, it should still have the coating on it. Don't run the chain to tight and put 16 oz of oil in it.
Yes, 8.5 oz is for Apex, etc. The Cat/Winder chaincase takes 12 stock, but some of us have bumped it up to 16.Ok is that what you guys are running 16 oz? My dealer told me 8.5 glad I asked/posted on here
PowderFalcon
Pinnin' it!
Well said. Tack weld the set screws, run chain loose, and 16oz oil. I’m on my second bushing. Interested to see how it holds up.
I just pulled apart an 18(stock) that had never been apart and the top bushing was worn quite a bit and had to be replaced.
I also just pulled apart a 13 1100 Turbo(stock) that to my knowledge had never been apart(9000kms) and the bushing looked like new. This is the old style tensioner and I did notice the chain was on the slacker side.
I am convinced the main cause of these bushing failures is too tight of chain, like Clutchmaster had suggested(not that I want to toot his horn) lol.
The chain adjuster is to be set at 1.5 turns out from finger tight. IMPORTANT
Turboflash
- Mar 18, 2019
- Southern MN
Ditto!The chain adjuster is to be set at 1.5 turns out from finger tight. IMPORTANT
uofm
Replace the bearings. 1200 miles and mine fell apart. Getting them replaced right now.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Hi, sorry to hear, hopefully Yamaha sorts these issues out for ACReplace the bearings. 1200 miles and mine fell apart. Getting them replaced right now.
I see you are in Tawas, I have a place in Oscoda on VanEtten lake.
Any rideable snow in the area?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Yer the best Nitro!
Toot Toot
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Just give it a couple of weekends and it will be much looser then that on it’s own!
17 RTX with new chain last season. Adjuster found at about 2.5 - 3 turns out during pre season maintenance.
Thank god for his 22T whereas his chaincase nub damage was a bit less then mine back when I was using the stock 21T. Then again, (my LTX-LE) now it seems that with that nub piece (quess 3/16”)out of the way and with my 22T my loose chain does not cause anymore wear to that nub. His may be worn in also now... I just cannot believe more are not reporting the same issue. You do need to take all out of that chain case, to see that damage though.
I guess only in Maine!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
congratulations on your new sled!!!
There are a few common issues every brand has them!!
Take some time and read through Rockerdan's build thread and you will be all caught up
https://ty4stroke.com/threads/my-rtx-le-50th-build-thread-let-the-mods-begin.149801
Gman25
- Dec 11, 2019
- ottawa
1999 srx 70
1993 vmax 750
Thanks a lot guys great advice I msg rockerdan for some advice and also read his build thread very amazing thank you.
I have replaced every brg in skid as well as jackshaft and drive. My only good news is jackshaft brgs and my drive axle brgs were all in decent shape but I replaced them all anyways with ntn and skf in skid. So at least I know every thing is new. Piece of mind.
I am now going to search the forum for shock set up on the qs3. I am 205lbs and would like to get a starting point.
thx All
thx All
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
What’s the advantage of 16oz of fluid vs the 12oz needed? Is there a plus to an extra 4oz?
- 40K
- 14K
