Ya,it sounds like our 17 it had 5 holes up top,but maybe just the one on bottom,i never removed it from the bottom though,so you like it so far? And you are close to my weight 240-250# ok maybe suited up 260lbs lol your torsion rear springs will take set in at about 700-800 miles depending on how hard you pound them,mine now I have to have them on max #3 setting or I bottom on stops or transfer blocks,and that is compression setting on #2 clicker,dont think you will ever use 3# unless jumping roads,front coil over shock at 2# as well spring set min. if you preload it to much it will setup the back for #*$&@ kicking. Good luck. pete
