ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
As far as the holes to tunnel location, same spot on the 19 and 20 I compared. Upper most forward hole.I think that someone mentioned that the mounting holes for the front torque arm were lower on the tunnel.
Dan
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
I read somewhere the same thing. Looks like the geometry changed a bit on the skid. I'll see if I can find the article I read. I think Cannondale posted it someplace as well.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I heard an opinion about the hole so I looked today at show....
I also heard the straps were longer for 20. But hard to say without measuring them.
Dan
Dan
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
Front shock and strap are longer .shock has different part # and cost quite a bit more
That would make the most sense.Front shock and strap are longer .shock has different part # and cost quite a bit more
putz21
- Apr 15, 2013
- Tomahawk, WI
Straps on '20 are 1/2" longer.
putz21
- Apr 15, 2013
- Tomahawk, WI
I believe the geometry of where the upper arm mounts to the rails have changed a bit. Supposedly, with it moving slightly, it also creates a bit more front travel. I need to find the article that I read.
putz21
- Apr 15, 2013
- Tomahawk, WI
Here is one of the articles: http://www.supertraxmag.com/feature...PJc-4jN5DKMwJ-aIpw2SiEDXyPGZk83vjeWv9m0IsTzHU
putz21
- Apr 15, 2013
- Tomahawk, WI
Here is a pic of the '20 rails.
race24x
- Dec 29, 2003
- Belgrade, Maine
- www.r-scomputer.com
Just upper arm and Spindle. The mounting point for lower arm is up higher on spindle. Width should stay same unless using the cat race sled setup. Not sure if any other geometry changes were made in arms,spindles or rear suspension.
Hey there how do you widen the front end? I see you said something about the Cat race setup. Also I see that we can do this swap on the 17/18 as well just upper A arm and spindle?
Cat race setup is wider than stock.Hey there how do you widen the front end? I see you said something about the Cat race setup. Also I see that we can do this swap on the 17/18 as well just upper A arm and spindle?
race24x
- Dec 29, 2003
- Belgrade, Maine
Can I run the Cat race setup on my 17 Winder any help on where to find those parts? Are they readily available through Cat?
race24x
- Dec 29, 2003
- Belgrade, Maine
Hey PUTZ I have those same shocks. How do you like yours? I am sending mine out to Hygear to get them dialed in. Mine are stage 5 allot of clickers to mess with
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Why Hygear?Hey PUTZ I have those same shocks. How do you like yours? I am sending mine out to Hygear to get them dialed in. Mine are stage 5 allot of clickers to mess with
They are pushing AXIS and FOX......
race24x
- Dec 29, 2003
- Belgrade, Maine
I already bought them, but they are still a bit harsh. They can rebuild them on a shock dyno and hopefully make them better. Plus I am sending my fronts to be revalved and have the dual rate springs put on. I used them for my Apex rebuild and dual rate springs and it was awesome
