Yes look up 600 xc 2019Can I run the Cat race setup on my 17 Winder any help on where to find those parts? Are they readily available through Cat?
race24x
- Dec 29, 2003
- Belgrade, Maine
- www.r-scomputer.com
I tried searching for this. Has anyone done this and done a write up. How does it work? Just replace a few parts like upper aarm and spindle?
Not that I know of. Its Everything including shocks and both a-arms/tierods.I tried searching for this. Has anyone done this and done a write up. How does it work? Just replace a few parts like upper aarm and spindle?
Even Swaybar is different # Than other 19's.
race24x
- Dec 29, 2003
- Belgrade, Maine
Maybe it isnt worth doing and I can get the 20 front end for much cheaper it seems like. I loved the widening kit for my Apex though
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Hi anyone know the torque spec on upper ball joint on this front end.
Thanks Pan
Thanks Pan
Looks like 45FtLbsHi anyone know the torque spec on upper ball joint on this front end.
Thanks Pan
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
cannondale27 pulled through once again.once all together I will post pics as well.Looks like 45FtLbs
Thanks Pan
gerbes2
- Dec 9, 2017
- mn
- sidewinder
Looking for an update from anyone that upgraded front to 2020 geometry. What other components had to change?
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
Other than the parts listed above for the front, the geometry changed a bit where the front arm mounts to the rails in the skid (from what I have read). That being said, the rails must have changed on the 2020's in addition to the limiter straps being 1/2" longer.
Crazy Canuk
My 2020 skid is in the middle of my garage floor. If you want specific pictures, I can try and get them tonight if my memory doesn't fail me. Let me know.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I'm pretty sure the limiter straps and front skid shock are different. I'll have my 2020 in the air today and can take a measurement of the front shock
putz21
- Apr 15, 2013
- Tomahawk, WI
Please do measure the front shock and let us know what you find. I was thinking the shock length would be the same from ‘17-‘20’s with the difference in the location of where the front arm mounts to the rails, which changes the angle a bit on the arm. Not necessarily changing the length of the shock, however, needing to lengthen the limiter straps by 1/2”.
Just my guess so would love to hear what you find out.
hellflyer
- Dec 2, 2008
Cat has a totally different part # for the 20 shock and straps and it's more expensive. Yamaha doesn't list 20 parts yet as far as I could find.
hellflyer
- Dec 2, 2008
Just measured the front shock center to center of the eyes is 12 1/8" roughly installed length and it looks like there is another hole in the limiter straps but don't know yet if that will over extend the shock yet!
