theCATman
- Feb 19, 2007
- WI
- Yamaha
Switch dealers
Although I agree, this is really no different that the plague of bent 08 FX Nytro subframes, 05-07 973 engines with bad timing chain tensioners.
Every stealer claimed they never heard of the issue before. (Rolling eyes)
The bearing is better protected than the all-Yamaha models were. It has that extra seal towards the inside to help keep snow, ice and water away.I always needle greased the speedo side axle and Jackshaft bearings on the rx1's, vectors, apex, and friends nytros, etc., as it's super easy. Continuing the tradition is a little more work on the sw, so I grease and prick punch the shaft a little more each time. No spinning yet, and bearing looks like new and brake comes off the spline easily. The Yamaha bearings always get some water in, but the sw bearing is always clean.
Snorunner
- Jul 17, 2018
- Deerwood
- 2016 Vector XTX
2017 Vector XTX
2001 Arctic Cat
I know I have seen Loctite Green mentioned before. But what about Loctite 609 bearing mount. Heard about it today from a Mine mechanic. I was installing a machine on the Iron Range today. He noticed my Yamaha hat we started talking Yamaha sleds. He has a VK with a 1000 cc four stroke. I told him I wanted to buy a Yamacat. But I started explaining the Cat related issue with the driveshaft. He immediately brought up this product and said it would set the bearing up to 10 thousands of an inch of clearance?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
That’s been tried by a couple guys. Still spun eventually. Chassis flex plays into this issue also.I know I have seen Loctite Green mentioned before. But what about Loctite 609 bearing mount. Heard about it today from a Mine mechanic. I was installing a machine on the Iron Range today. He noticed my Yamaha hat we started talking Yamaha sleds. He has a VK with a 1000 cc four stroke. I told him I wanted to buy a Yamacat. But I started explaining the Cat related issue with the driveshaft. He immediately brought up this product and said it would set the bearing up to 10 thousands of an inch of clearance?
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Caterpillar has a bearing mount product also, worked pretty good on heavy machinery when I worked at Ziegler’s. I was going to use some when swapped my track but the bearing fit pretty tight to the axle and I seen no signs of spinning with 3,500 miles on mine so I left it alone.That’s been tried by a couple guys. Still spun eventually. Chassis flex plays into this issue also.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
That’s great yours is good. I certainly believe some shafts and bearings are fine. The shaft size/diameter where bearing sits is ever so slightly different from one shaft to another.Caterpillar has a bearing mount product also, worked pretty good on heavy machinery when I worked at Ziegler’s. I was going to use some when swapped my track but the bearing fit pretty tight to the axle and I seen no signs of spinning with 3,500 miles on mine so I left it alone.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
So in the past two years yamaha trademarked SXVENOM,SNOSPORT,MOUNTAIN MAX!!LET YOU IMAGINATION RUN WILD GUYS..The mountain max was renewed a month ago
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
SRVenom or SXVenom? The SXViper went to SRViper in the procross chassis so maybe SXVenom new Yamaha chassis?So in the past two years yamaha trademarked SXVENOM,SNOSPORT,MOUNTAIN MAX!!LET YOU IMAGINATION RUN WILD GUYS..The mountain max was renewed a month ago
The redhead is never dead
- Jan 16, 2020
- Blunder Bay
- 02 viper
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
Well, which one is it?
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
The newly trademarked name is SXVenom.
Carbide
- Apr 20, 2017
- Elk River, Minnesota
- '15 Apex X-TX -SOLD
'21 Sidewinder L-TX SE
- Minnesota
Just a few short weeks until we get some sneak peeks.
Snowman871
- Feb 9, 2010
- Woodville, WI
- 2024 Polaris Assault 850
Just a few short weeks until we get some sneak peeks.![]()
When is the official release date?
Carbide
- Apr 20, 2017
- Minnesota
No idea. Usually by the first week of March.When is the official release date?
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
I've heard that the official release date is March 10th.
- Status
