WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
What is the advantage to this?[/QUOTE
Main reason I did this too is I had to crank the centre spring to take weight off the front to lighten up the steering effort but I killed my plushness in the rear suspension doing this..What is the advantage to this?
Now with bolt moved to the upper hole I have little preload in centre spring and rear suspension rides nice and steering effort is minimal..
Also like other guys have said and with mine the track doesn’t sit flat/parallel to ground when it’s in the lower hole, now with the suspension moved my whole length of the track is in contact with the ground.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
What rebound setting?let me knowOk fellas I loosened up front springs and did the rebound setting everyone said to do. Now I moved this bolt up to top hole. I'm leaving in morning to to for the weekend and don't want to be off to bad on set up. Am I gonna be close or gonna push bad? Thing is big group of hard riders and don't want to be out to lunch! Thanks
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Does this make it transfer any better?
Confused
- Oct 12, 2008
- Mound, MN
- '25 Sidewinder SRX #723
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
Just set mine down on the garage floor after moving it to the top hole. Noticed right away less sag when sitting on it. Will know more this weekend.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
What models came with the bolt in the bottom hole? Thundercats and my 17 RTX are all in the top hole
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
2020 LTX-GT and XTX-LE. Completely different skids though.What models came with the bolt in the bottom hole? Thundercats and my 17 RTX are all in the top hole
Confused
- Oct 12, 2008
- Mound, MN
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
2021 LTX SE
WinderFab
- Mar 1, 2009
- Woodbridge, ON
When they switched to the new front end in 2020 they also put the rear suspension in the lower hole.What models came with the bolt in the bottom hole? Thundercats and my 17 RTX are all in the top hole
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Yes.. my ltx always felt glued to the trail no matter how much throttle or how firm the trails were..Does this make it transfer any better?
Now you feel the weight transfer more..
My last ride with hellflyer, he confirmed skis were in the air on a rail bed
STAIN
- Feb 29, 2004
- Vermont
- Vermont
But Cat did not, the Thundercats are in the top hole.When they switched to the new front end in 2020 they also put the rear suspension in the lower hole.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Exactly.. all the 20’s and 21’s cats I’ve seen on the trail have the suspension in the upper hole. Nobody knows why Yamaha decided to go to the lower hole, it is a cat design after all..But Cat did not, the Thundercats are in the top hole.
Even though the holes are close together it makes a big difference between the two locations. Like I said before on my ltx in lower hole the track doesn’t sit flat on the ground, on upper hole it does.. weird..
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
- ramody44@yahoo.com
I believe all ARCs front ends. My 20 SRX is like this.What models came with the bolt in the bottom hole? Thundercats and my 17 RTX are all in the top hole
vice108
My 2020 LTX-SE is in the bottom hole.
hognit09
- Mar 7, 2010
- beaver dam, wi.
- 2016 viper ltx le,2016 viper ltx dx
Prolly a dumb question, but can this be done on the 14-19 vipers?
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
All '14 - '19 Vipers already have the rear suspension mounted in the top hole. It's the Yamaha's '20 - '21's that have the suspension mounted in the bottom hole, which some people are moving to the top for a better ride. Arctic Cat has kept all their years '14 - '21 in the top hole.Prolly a dumb question, but can this be done on the 14-19 vipers?
So this is the big question that has been unanswered as why Yamaha has the +2020's with the ARCII front-end mounted in the bottom hole while the Arctic Cat's +2020 with same ARCII front-end have theirs mounted in upper hole like all previous years.
- 6K
- 10K
