Mike Radlein
- Nov 5, 2017
- Illinois
- 2017 Yamaha sidewinder ltx-se
anyone know what a 1702-191 is?
as thats what the dealer gave me when I ordered a 22 tooth top sprocket
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
Its a sign.......no more Yamaha.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
as thats what the dealer gave me when I ordered a 22 tooth top sprocket[/Q
That gear will not work . It' the old style rexnord gear and won' fit the hyvo chain you have now.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Those are for the older cat models 2012/13 i believe...likely a POOR Material(sintered) and def not a Borg Warner, so you would likely trash your chaincase in a short time. I recommend not running that!anyone know what a 1702-191 is?
https://www.countrycat.com/arctic-cat-part-1702-191-sprocket-22t-rev-15w-w-brg-assy
https://www.ebay.com/itm/ARCTIC-CAT-SPROCKET-22T-REV-15W-2602-213-SB-TO-1702-191-/400887301672
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
We had a guy try to use one of those, and what happened is he could not get the chain to fit, we were all baffled as the 22 fits with stock chain. So upon very very close inspection, we found the chain did not fit down perfectly into the teeth, we thought it was a pitch thing, but I now believe it may have been the diff between the rexnord NON HYVO style teeth and what our new HYVO teeth look like.
Dan
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
As has been said.
DO NOT USE THIS GEAR!
It is sintered, and it's not a Hyvo sprocket, its an old silent chain sprocket. You will eat up the gears and chain if you try and run it.
yamaha06
I also can't find any 22 top gear anywhere so I guess I will just run the stock 21/41 for this season.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Not to worry, unless you have the room and conditions and a tune, to run over 126mph(GPS) then you will likely not ever miss the 22 tooth. And the 21 will be more fun on trail and likely easier on belt(heat) and maybe a bit snappier to boot.I also can't find any 22 top gear anywhere so I guess I will just run the stock 21/41 for this season.
I plan to run mine stock for several weeks before I start to apply all the goodies....Got to ride mine finally yesterday, and bone stock this thing is just crazy impressive! Lexus like smoothness and quiet, YAM did one hell of a job on these sleds outa the box. Feels like a premium TESLA! And its a rocket!
Dan
KnappAttack
- Feb 19, 2004
- Welch MN
If you don't have one now, you will not find one till Feb.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
haha, I should sell my brand new 22 gear! LOL
Do I hear a bid?
Do I hear a bid?
KnappAttack
- Feb 19, 2004
- Welch MN
Check your PM Dan.
Mike Radlein
- Nov 5, 2017
- Illinois
Thanks everyone for the response on the 1702-191 question.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
How's the 129 transfer?Not to worry, unless you have the room and conditions and a tune, to run over 126mph(GPS) then you will likely not ever miss the 22 tooth. And the 21 will be more fun on trail and likely easier on belt(heat) and maybe a bit snappier to boot.
Dan
yamaha06
Ya I know, and I won't be ripping in to the chaincase in feb to install the new gear. Riding is to short to be doing that kind of stuff lol.
nightrunner06
- Nov 18, 2013
- madison, wi
- SideWinder LTX se
pro - x Axys switchback 800
I ran out of gear on my stock sled last year without a tune. (21/41) I found a 22 top gear on eBay out of a xf9000 high country. But I can't find any more. The next step would be a gear set from Scott Taylor, which are bullet proof.
