jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
hole size on upper left fuel tank
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Hole location.. THIS is the furthest you can drill as you will see in pics.. The mark I show is fine but you may want to move it 1/16" inward towards the center of fuel assembly. Nothing wrong with my hole location just very close to being to far.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
This is the underside of the top cap for fuel slipper/banana that fuel pump sits inside of.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
more pics to come. Got to resize
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Now these little white plastic tabs are a tad tricky until you realize you need to turn them with needle nose pliers.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
And last but not least. The fuel assembly goes back in a certain way. Kinda obvious for most guys on here. But the yellow marks I added show the mark that lines up with fuel nipple. Any questions pm me. This really is a easy mod and a must for tuned sleds IMO. While your pulling the fuel assembly mine as well put a bigger capacity fuel pump in especially if tuned.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
@jonlafon1 Thanks a lot!! I was watching this thread and decided not to mess with it as I haven't had any issues, but with your write up I'll go ahead and tackle it. Ordering parts today.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Pm if you get crossed up.
GodSpeedSWE
- Jul 30, 2019
- Polarcircle
- Sweden
- -19 AC XF9000 HC
Exactly the same way I did mine with one small exception. I made a stainless plug for the standard hole in the tank.
One question about the fuel pump upgrade does this not require a bespoke flash? Or maybe pressure is not affected just flow? What's the common upgrade Walbro 255?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
The fuel pump upgrade is just a slightly higher capacity pump. I use the TD one. Cheaper options available around. No flash or anything it’s just a upgrade and a good idea if your going past a stage 1 tune. So stock and or a 240/eco trail tune the stock pump is fine. Anything more Imo upgrade the pump.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
TD OR Hurricane sell pump upgrade. Or Walbro?
Not sure which. Someone will chime in.
1NC 2000 I believe went with a walbro just not sure which one.
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
I went with a 190lph from Tommcat, but I don't think he sells it anymore.
