Lebowski
- Jan 14, 2015
- 2016 Viper RTX SE
Hi all, this may have already been discussed and I missed it, but I have a 16 RTX-SE with about 950 miles on it. After reading all the horror stories about Tri-hub failures I am trying to decide if I should replace the Tri Hub with a J&T or would I be good with just adding the J&T 4th wheel kit? Any advice or suggestions would be appreciated.
Rye_Guy78
- Oct 31, 2014
- 2015 SR Viper LTX SE
I got two seasons, 5000 miles out of mine. Just put JT's kit in. The tri hub didn't fail but it would have this year, the bearings are rough. If you are going to buy a kit you might as well replace the whole thing now.
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
The true fact of the matter is that the plastic is very flimsy. I took mine out before I ever rode it and put in a Larson Racing one. I had heard the stories about the factory ones and made a decision to get a different one. Once I took it out I must really say that it is pretty flimsy. Once you take it out, you will see. That being said, not sure how putting a few more wheels on it is going to help make it more solid. Get a good 4 wheel kit and sleep better.
Lebowski
- Jan 14, 2015
- 2016 Viper RTX SE
Ok thanks guys. I know I am preaching to the choir, but it pisses me off that we spend this much on a sled and then have to keep spending on issues that should have been addressed at the factory just to feel comfortable and safe on them.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
2016 ltx le 3000 miles. Tri hub was in great shape. I changed out the bearings with higher end ones. I like the trihub look. I see no reason to go fourth wheel
Rye_Guy78
- Oct 31, 2014
They must have changed the tri-hub for 16, in my 15 the bearings are not replaceable.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
They did change the style with replaceable bearings
Alsim
- Oct 6, 2014
- LTX SE 2018
Same...I changed bearings in it each season . No issue ...2016 ltx le 3000 miles. Tri hub was in great shape. I changed out the bearings with higher end ones. I like the trihub look. I see no reason to go fourth wheel
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2017 Sidewinder BTX Hurricane 270 tune
2015 Viper X-TX LE MPI turbo
I just replaced mine with the upgraded 2016 one and a 4th wheel kit...just couldn't justify the cost of aftermarket with exchange and shipping to Canada...almost $175 cheaper...that's a lot of bearings!
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
I thought 15 and up where replaceable, got 3300 trouble free on trihub, but bought jt 2 wheel replacement this season.They must have changed the tri-hub for 16, in my 15 the bearings are not replaceable.
upei93
- Apr 27, 2008
- Dalhousie, NB
I thought 15 and up where replaceable, got 3300 trouble free on trihub, but bought it 2 wheel replacement this season.
My 15 had the non replaceable...
Your 15 is a early build. Was no replaceable bearings.My 15 had the non replaceable...
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
If you have it apart, its likely worth the time to upgrade.
We had to leave a buddy behind when his tri hub failed and that left a stark impression on me. He sat around for 2hrs until we returned and got to him with the truck and trailer.
MS
MS
rbell14
Mine failed at 1700 miles. Totally stuck on trail when it happens. I went with JT products 4th wheels kit. WAY better support and better bearings and th 4 wheels dispurse the working load across 4 bearings.
- 10K
