johan
I would if I were due to open it up but serviced it all in spring before we had any idea 17 bearing might work. Just wish someone would confirm bearing will work. I believe it will even work with 16 shaft. Just need to be sure. I think all these people updating to 16 will wish they did 17 to get rid of that Wobblebearing. 17 bearing has proven itself now.
I am gonna replace the wobblebearing to a double row bearing
Janne339
4206 german FAG bearing and the drilled Sidewinder gear
![Bling :bling :bling](/styles/default/xenforo/smilies/bling.gif)
Janne339
Stock gear and Sidewinder gear. And the old -16 PEER wobble bearing.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
Original top gear Janne?
What are you going to go for chain tension? I see your chain hit pretty good.
Janne339
With 4206 bearing I gonna try 0.25-0,5 turn out. The mcx 270 put a lot of stress on the drivetrain. 1,5 turn was to much and chain wave hit the chaincase.
johan
Dont go less then 0.5 turn Janne339 its a long chain dont forgett that.
When new I could not run 1/4 turn. Whined on decel bad. I am going to try 1 turn out I believe.
Janne339
Ok Johan. Gonna check it out when I got my new track an put everything together.
Do the chain tension before putting tank/cover back on. Then you can see whats going on and Finger it out!
johan
johan
johan
johan
You guys that want to keep wobble bearing can go with skf 22206e 9500rpm, static 64000 newton
Tell me about the new bushing and why you see the Wobblebearing as being burnt?You guys that want to keep wobble bearing can go with skf 22206e 9500rpm, static 64000 newton
