If you make it I will put it on first page. But it is all there I believe.Can we make a sticky on the parts needed to switch over to a 16 shaft? Or w.e maybe the best upgrade possible? Plz and thank you.reading through all these pages to gather some info got my mind racing
twiz28
- Nov 8, 2004
- New Brunswick, CAN
- 2017 Sidewinder BTX 1.75 Backcountry
2017 Sidewinder XTX 137
Ok I just put my flame retardant suit on in preparation..... I opted to just replace the wobble bearing in my new to the wife 14 xtx with the FAG bearing and locking collar sytem as original. Nothing in case should any signs of wear, which is a miracle because previous owner had the chain so damn tight it must having been singing and probably was that way for all of its 7500 mile life. Million dollar question is does the bearing only go in one way, got it all together fine, in the middle of the night woke up in a cold sweat thinking that bearing must have a tapered bore???????? Everything went in fine, torqued it to 36ft-lbs, spacers and lock ring lined right up everything works smoothly. So if it needs to go in in a specific orientation i.e larger diameter of inner bore towards back case so locking collar can "pull" into it as you tighten nut I must have gotten it right?????? Thoughts?????. I know I know should have upgraded to 16 set up but was waiting for the jury to return on the 17 option as in my Winder.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Bearing are not tapered (2016 and up )your fine.
SnoBird888
- Sep 4, 2013
- Neenah, WI
- 09 Nytro xtx
what is this bushing i keep reading about on the top gear?
Great read. I am going to ride my 2016 1 more year and tear it down next summer.
twiz28
- Nov 8, 2004
Inside of top gear is a bushing, it wears and allows play on shaft, when new bushing has a grey coating, when wore appears bronze.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
https://www.mcmaster.com/#6381k563/=1aqljm9
This bearing will need about 1/8”~1/16” cut off on the length should fit but might need a little sanding on the inside diameter once it’s pressed into the gear. I’ll let you guys know how it fits.
14 and 15 is tapered. But I don’t believe nut can be put on if you put it in backwards. I will check after work.Bearing are not tapered your fine.
Just checked. There is no way the nut will go on if Tapered bearing is put in backward. You definitly have it right. Rest easy and go ride that thing. you deserve it!Ok I just put my flame retardant suit on in preparation..... I opted to just replace the wobble bearing in my new to the wife 14 xtx with the FAG bearing and locking collar sytem as original. Nothing in case should any signs of wear, which is a miracle because previous owner had the chain so damn tight it must having been singing and probably was that way for all of its 7500 mile life. Million dollar question is does the bearing only go in one way, got it all together fine, in the middle of the night woke up in a cold sweat thinking that bearing must have a tapered bore???????? Everything went in fine, torqued it to 36ft-lbs, spacers and lock ring lined right up everything works smoothly. So if it needs to go in in a specific orientation i.e larger diameter of inner bore towards back case so locking collar can "pull" into it as you tighten nut I must have gotten it right?????? Thoughts?????. I know I know should have upgraded to 16 set up but was waiting for the jury to return on the 17 option as in my Winder.
Backward
Correct
twiz28
- Nov 8, 2004
Thanks man! Was pretty sure I had it right but second guess myself!!! Hopefully get her all put together this week and rip on weekend. Appreciate your help and follow your posts.
ski
- Feb 7, 2006
- Manitoba Canada
- 2015 Yamaha Viper R-TX LE
My 15 Viper RTX now has around 300 miles on the SKF 4206 bearing with the updated 2016 shaft. So far, so good. Nice clean fit and relatively cheap if you just buy the shaft, not the assembly with clutch side bearing and holder.
Sent from my LG-H873 using Tapatalk
johan
- Jan 19, 2015
- sweden
- Sweden
- Viper Xtx mcx 270
Have run the 4206 now for about 90miles now with 300hp. I have the chain on 1 turn out, it works really good and no bad grinding noise. A lot less sound from engine brake now in the chaincase, so far so good
Got about 300mi on mine at 1 out. All good here too.
johan
- Jan 19, 2015
- sweden
- Sweden
- Viper Xtx mcx 270
cannondale did you run the 4206 bearing?
Stock 16 parts.cannondale did you run the 4206 bearing?
ski
- Feb 7, 2006
- Manitoba Canada
I had a look the other day while swapping gears and all is well with the 4206 bearing and 2016 jackshaft in my 2015 Viper. That's over 2,000 miles this season so far.
