TinMule
- Feb 23, 2020
- West Nipissing, ON
- 09 Venture RS
07 Venture Lite
In a middle of a taking apart the arms on my 07 VL.
trying to source bushing (other than plastic).
Would you know if these, listed for an '09 fit?
07 part no: 90381-16N51-00
09 part no. 90381-16003-00
part no listed on Kimpex: 90384-16N51-00
looking for 24/28 on the lower a
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
That Kimpex bushing doesn't look right. It doesn't have a lip. Maybe it's for the ski spindle?
The Oilite bushings usually come complete in a kit. If you can find one for a Phazer, it will fit the VL/MP. May be getting hard to find. Didn't see one in the RD catalogue or on Ulmer's site. Check this thread for possible sources:
Phazer Oilite A-Arm Bushing Kit Discontinued
I placed an order for one of the Oilite A-arm bushing kits with Yamaha Canada. I just received a message that this kit SMA-8GCFR-KT-00 has been discontinued. I'm disappointed that such an essential part would be discontinued. I would be understanding if it's a backorder issue but it doesn't seem...
ty4stroke.com
Pat tremblett
- Feb 8, 2015
- Ottawa
- 2014 Yamaha Venture MP
I just had my A Arm bushings on my 16 mp replaced. I can ask the guy where he got them. He is a mechanic buddy who did it.
apeddigrew
If you could please and update. steering my 07 VL is murderous atmI just had my A Arm bushings on my 16 mp replaced. I can ask the guy where he got them. He is a mechanic buddy who did it.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
They're available at Schmidt Brothers:
Ski spindle bushings at Ulmer:
Sloppy Steering Fix | SchmidtBrosMotorsports.com
This kit totally fixes the slop in the handle bars on all Phazer models. There are 18 pivot points in the Phazer steering and the collector at the bottom is far too loose from the factory. This kit will tighten up the steering collector and pitman arms which will make a dramatic difference in...
www.schmidtbrosmotorsports.com
apeddigrew
Thank you Mooseman! so much appreciated! Happy trails!They're available at Schmidt Brothers:
This kit totally fixes the slop in the handle bars on all Phazer models. There are 18 pivot points in the Phazer steering and the collector at the bottom is far too loose from the factory. This kit will tighten up the steering collector and pitman arms which will make a dramatic difference in...www.schmidtbrosmotorsports.com
apeddigrew
Sorry, are these two different kits (with different benefits) that will fit the 07 VL? Thank youThey're available at Schmidt Brothers:
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
The Schmidt Bros is for the lower linkages at the inner tie rods that is a design flaw and the Ulmer is for the ski bolt bushings which usually the original thin metal ones fail and make the ski loose in the spindle.
Check with Ulmer for the ski bushings as I just remembered that the VL's are wider than the Phazer's. Not sure if the Nytro's would work.
apeddigrew
Perfect! Thanks again!The Schmidt Bros is for the lower linkages at the inner tie rods that is a design flaw and the Ulmer is for the ski bolt bushings which usually the original thin metal ones fail and make the ski loose in the spindle.
- 115K
