rbell14
Is the two prong plug on the 2015 RTX SE? I just checked mine and did not see one. Does any have a pic?
You have to undo the dzus fastner pull panel back and it's right by the reverse actuator on chain case.
rbell14
Looking at the sled right now. Don't see it. I assume this is on the muffler side of sled
rbell14
Here is what I see. Which one is it?
Its deceiving since is a dummy plug with a wire coming out of it. Remove the plug and plug yours in.
rbell14
That's it. Pull it apart. It's one with black and red wires and the loop going around your pointer. In my pic I have the cord connected already.
rbell14
Thanks man!
No problem.
TD Max
I'm thinking I might try one of Rock's Smart Supply devices as I will need to power a GPS as well. This would be a great place to pull power from.
rebmo
- Mar 8, 2014
- Rural SE Wisconsin
- 2015 Yamaha RTX-DX blk
2015 Arctic Cat XF 9000 Green (Turbo)
Any source for a plug to connect to the Jack on the viper? The wires from my shield have only 2 eye connectors black/red on th possibly intended for a battery hook up. I'd like to replace the eyes with a compatible connector if they are available. I'd prefer a switched accessory connection to protect the battery.
TiA for any connectpr source info,
Reb
Reb
You can either use a adapter for cig socket to RCA or go to plug shown in pics above. All AC dealers have both or any sled dealer will have the cig socket adapter.
rebmo
- Mar 8, 2014
Thanks, I'd like to use the jack "in the pictures above" and leave the cig plug for GPS and cell. I'll check with my dealer. Sells Yamaha & AC so sounds like they will have the plug
Thanks, Reb
Thanks, Reb
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Check this out he is a Ty Member. http://yamaheater.com/Products.php smart supply works great.
That would work nice.
