shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Does the machining fix problems on stock clutching? Does some of the aftermarket clutching fix issues alone or is it recommended to machine clutch even with those set ups?
I can only speak for the Thunder products kit. But can tell you the stock secondary binds the spring. Give us a little time. We are looking at different solutions and need to test.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
If guys are NOT having issues with secondary leave it alone.. Some sleds may not need secondary machined.. If your blowing belts and have a lot of dust and HOT secondary. This machining will help.. I will report ASAP what I find . Leaving Thursday for the UP . Should get some miles in.. Also I have a fresh belt to run after I clean all the dust out _ fresh start to see differences so to speak.Does the machining fix problems on stock clutching? Does some of the aftermarket clutching fix issues alone or is it recommended to machine clutch even with those set ups?
The only difference on set up is NEW belt( 8dn )and secondary machined, and offset checked and rechecked. I had a ton of belt dust on last 300 miles with new 8dn.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
That's what gets me. How do we explain the variability with the clutches? The Proto's ran over 120 some guys here are getting over 120 and then others are having coil bind roller problems and blowing belts.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
inconsistent manufacturing of the HELIX and spring(secondary in general maybe?). Hell the factory rollers might have made it and been okay IF ALL three were touching helix. And some are doing okay with them
This is almost to a T what happened in 2012 with the Cat 2 roller secondary. Only difference is the Cat was a compression secondary/ Yamaha is a torsional with three rollers instead of 2 that cat had. My 2 cents anyway
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
The other issue that I forgot to mention that I have seen - more cat side of things .. Is the Primary spring binding also. Guys would machine the pocket a touch wider on the cat clutch. Not Deeper in the pocket but actually slightly wider diameter in Primary spring pocket. Not saying this is happening BUT this is a somewhat new Yamaha primary and maybe just something to spot check(primary spring wear)inconsistent manufacturing of the HELIX and spring(secondary in general maybe?). Hell the factory rollers might have made it and been okay IF ALL three were touching helix. And some are doing okay with them
Thanks !Yes
WINDER1987
Is it possible to adjust weights or arms anyway with out removing primary bolt cover spring etc?What is your secondary set at.
Change tip to 7/16 with thin washer.
shagman
Vendor
- Feb 18, 2014
No. but I can save you one step. Primary bolt doesn't need to be removed, just cover. Who's tune are you running.
WINDER1987
No tune all stock except D&d exhaust
WINDER1987
No tune all stock except D&d exhaustNo. but I can save you one step. Primary bolt doesn't need to be removed, just cover. Who's tune are you running.
That doesn't run lean?No tune all stock except D&d exhaust
WINDER1987
D&d told me I didn't need one if I left the insert in the exhaust but needed a fuel programmer if I removed the insertThat doesn't run lean?
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Ya,but my cat had so many more problems than there secondary pos,the whole set up of the TCL was a joke,EVO hit the nail on the head when they started to develop there delete kit for the TCL POS...lolinconsistent manufacturing of the HELIX and spring(secondary in general maybe?). Hell the factory rollers might have made it and been okay IF ALL three were touching helix. And some are doing okay with them
The clutch kit on a SW with 200kms is not match for one with 1500kms on it.
My buddy's sled is completely stock but I guess broken in, he caught and pulled by me.
Loose trails only 100mph or so
Frozenstiff
- Dec 24, 2009
- Prescott, Ontario
- 2013 Arctic Cat Turbo
Interesting. Does anyone know when the break in mode is over on a Sidewinder, or Cat ?
Is it calculated by engine hours, or miles driven ?
