gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
that hose lets the crank case breath oil can come out from it in a roll over if you are getting watter in the air box it has a hole in it somewhere seems like its been a thorn in your side for awhile now i would get a new used air box.
apex55
Do you have all the tabs on the lid. Check if the seal is there also.
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
Yes they are I got a new seal today to try that out see if it fix itDo you have all the tabs on the lid. Check if the seal is there also.
apex55
A dumb question but you have the four locking spring clips closing the corners? #13
Jonesynl
- Nov 6, 2014
- Roberts Arm, Newfoundland, Canada
- 2008 Apex MTX SE
I was wondering the same. I don't get any water buy little bit of moisture in mine, is it from the warm air and then it turns off cold causing that?
apex55
There is also supposed to be a foam air filter element that goes under the screen in you picture. I would be
8FP-14451-00-00
ELEMENT, AIR CLEANER
8FP-14451-00-00
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
Will it hurt to put frogzskin on the end of itthat hose lets the crank case breath oil can come out from it in a roll over if you are getting watter in the air box it has a hole in it somewhere seems like its been a thorn in your side for awhile now i would get a new used air box.
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
I got one put its like the water sites on top of the screen I have the air mod toThere is also supposed to be a foam air filter element that goes under the screen in you picture. I would be
8FP-14451-00-00
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
i would not block that hose the watter is not commong in there. the worry is the watter getting into the motor thru the throttle bodies.
YAttak07
Is the hose in that picture taped? If it is it shouldn't be. The split in the tube is there in case the end of it freezes up and will still allow the crank to breathe.
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
It was like that when I got the sled I have to get a new one then Bc I took the tape off and some one glued it the split then taped it upIs the hose in that picture taped? If it is it shouldn't be. The split in the tube is there in case the end of it freezes up and will still allow the crank to breathe.
DoktorC
How much water are you getting?? That hose is a crankcase breather and it releases pressure...which is basically warm oily air. That warm air meets cold air in the airbox....and it condenses...making water.(which is why those hoses have a tendency to freeze). Don't cover the end...the hose doesn't suck as hard as the intake.
DoktorC
Put the slit back in with a razor blade...
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
That what it looks like is condenses it only on the screen and my air filter and in front of my air box will this hurt any thingHow much water are you getting?? That hose is a crankcase breather and it releases pressure...which is basically warm oily air. That warm air meets cold air in the airbox....and it condenses...making water.(which is why those hoses have a tendency to freeze). Don't cover the end...the hose doesn't suck as hard as the intake.
