Darren Betker
- Jan 16, 2017
- Dryden
- apex gt
Iv done a search for the actual instructions of how and where to cut but came up with nothing. Can someone please send me a link to the actual instructions of a modded box that actually gained hp? Looking for just the removal of material not any other mods.
justin gallant
- Aug 28, 2017
- moncton
- 2006 apex GT
- moncton new-brunswick
they say 6 to 7 go gain.and yup no is expensive..for 20HP gain with a yamacharger is over 2000$ oh well it's all fun!!Ram air box and fuel programmer will give you 6 hp gain
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
I installed d&d kit PCV with clutch kit and I put 12 of Schmidt Brothers circular are modules and got 164 on a 2011, so the right configuration works well. She pulls hard past 800 etecs.
LAKECITYAPEX
What EXUP/Tunnel Protector Kit are you using and how many studs did you put in? 164 is great.I installed d&d kit PCV with clutch kit and I put 12 of Schmidt Brothers circular are modules and got 164 on a 2011, so the right configuration works well. She pulls hard past 800 etecs.
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
I used the Yamaha tunnel protectors. However, I purchased solid brackets from Port Yamaha as the stock ones, which are not fully boxed can get soft causing the track to go higher and studs contacting EXUP = NO Bueno. 5000 miles so far not a single scratch with I think 144 Studboys down the middle or what ever the 128" track allows at 2 per, and super light plastic backers. In 5,000 miles I lost one backer and replaced 4 cracked ones due to having to ride down stone filled road with poor snow. Otherwise the whole set up is awesome, and super reliable.
Darren Betker
- Jan 16, 2017
- Dryden
- apex gt
Nobody recorded themselves cuttin up an airbox? Noone?
Please. Im about to do the 121 to 136 conversion and am doing an oilchange at the same time so im gunna have everything apart so id like to do the airbox mod at the same time. Id realky like to know what exactly i need to do. Pictures too instead of just being told would really help too.
LAKECITYAPEX
Thank you for the info, with 5000 miles sounds like you have a good set up. I will call Port Yamaha.I used the Yamaha tunnel protectors. However, I purchased solid brackets from Port Yamaha as the stock ones, which are not fully boxed can get soft causing the track to go higher and studs contacting EXUP = NO Bueno. 5000 miles so far not a single scratch with I think 144 Studboys down the middle or what ever the 128" track allows at 2 per, and super light plastic backers. In 5,000 miles I lost one backer and replaced 4 cracked ones due to having to ride down stone filled road with poor snow. Otherwise the whole set up is awesome, and super reliable.
RobX-1
- Coldwater, OH
Unfortunately, I may have purchased Kevin's last set as they no longer have a place to weld the extra support to the C-shaped tunnel protector. With that said, here's a picture someone posted in Tom's 'My 2018 Apex 50th XTX' post that shows the added piece welded to the existing tunnel protector. If it wasn't for Kevin rounding up his last set, I was planning on taking mine off and have a local weld shop add this extra support piece.
Darren Betker
- Jan 16, 2017
- Dryden
- apex gt
So.....any pics or instructions on how and where to cut on my air box?
Have you tried the Search function??
https://ty4stroke.com/search/804068/?q=airbox+mod&o=relevance
Whats the search function? LOL, can that be found under the seat on the sled? sorry I had too.
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
Thats them. Glad I got them right asway, though its not rocket science to weld a support piece in them.Unfortunately, I may have purchased Kevin's last set as they no longer have a place to weld the extra support to the C-shaped tunnel protector. With that said, here's a picture someone posted in Tom's 'My 2018 Apex 50th XTX' post that shows the added piece welded to the existing tunnel protector. If it wasn't for Kevin rounding up his last set, I was planning on taking mine off and have a local weld shop add this extra support piece.
Darren Betker
- Jan 16, 2017
- Dryden
- apex gt
Thanx for hijacking my thread guys. and yes i stated that i tried the search bar in my first post on the second page......and again.....found nothing.
So i went out on a limb and tried it on my own. six 1.5" holes drilled in a v formation on my lid.....and covered the holes with the same coarse foam the prefilter is made from from a shop vac. No idea if thats right
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I have a good used pc 3 for an apex if you want to add a programmer.
That shop vac filter is no good. You need a product like Frog Skin to cover the holes in your lid. This will allow air in and keep all moisture out. If you like I have a modded air lid for the ram air effect sitting on a shelf. Pay the shipping and its yours.
Gives the sled a real throaty sound.
