rat4020
- Oct 28, 2011
- Cold Spring Minnesota
- Polaris and Turboed Apex in a off road buggy
I want to move my turbo return oil line fom the timing check port to the center larger port in the stator cover and tap a An port into it . But I really dont want touse the nylon stock plug, does anyone here know of a after merket billet aluminum plug . I tried a YFZ450 but its to small
rat4020
- Oct 28, 2011
Found the correct plug, turned out good
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
You can drain the turbo oil back to behind the primary clutch as well. I have done it on a few units.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Hey that looks familiar ^^^
Since going oiless I now pull my crankcase EVAC from that port
bstylesclothing
- Mar 30, 2024
- San diego
- Rx1
If you don't mind me asking , where did you find the plugthat
rat4020
- Oct 28, 2011
I ordered it from amazon, they will show differnt sizes though. The first one I ordered was too small so measure your plug. The plug needs to be drilled and tapped for a -8 oring boss port and the inside lip of the plug needs to be machined concaved to give a bit of distance between the flywheel bolt and the plug so it wont create a restriction to the return oil flowIf you don't mind me asking , where did you find the plugthat
NICECNC Blue Engine Plug Crankcase Cover Plug Compatible with Yamaha YZ250F 2001-2013 YZ450F 2003-2005 YZ400F/426F/450F 1998-2005 WR250R/X 2007-2017 WR250F 2001-2002 WR250FX 2008 WR400F/426F 1998-2002
Visit the NICECNC Store4.4 4.4 out of 5 stars 6 ratings
| Material | Aluminum |
| Brand | NICECNC |
| Colo |
bstylesclothing
- Mar 30, 2024
- San diego
- Rx1
chemicalfusion
- Sep 27, 2024
- Prince edward island
- 2006 yamaha apex
Does this require a external pump and a resivoire under a rear mount turbo setup to work?You can drain the turbo oil back to behind the primary clutch as well. I have done it on a few units.
- Apr 17, 2003
- Menno, SD
- Menno, SD
On a rear mount, yes it would require a return pump and a small resevoir is never a bad idea.Does this require a external pump and a resivoire under a rear mount turbo setup to work?
chemicalfusion
- Sep 27, 2024
- 2006 yamaha apex
Ok thx would it be possible to be able to run the ruturn without a pump i have heard it is possible to run the return line using the engine vaccume but have not seen the setup would tapping a line to the oil fill cap on the top of the engine beside the coils work?
- Apr 17, 2003
- Menno, SD
- Menno, SD
I don't think it would work on the Apex models, due to the turbo being mounted lower in the chassis. It works on FX Nytro models, but the turbo mounts higher which provides a down hill run for the oil to come back to the engine.
