Northern
- Nov 18, 2015
- Whitehorse YK
- 08 Nytro
08 Phazer
I am attempting to remove the side cover on the engine to replace the stator
2015 Viper MTX
Oil drained
Exhaust removed
Lower oil line removed
Frame brace removed
Allen bolts removed around the perimeter of the side cover.
Side cover is loose but does not want to come free. I am scared to simply pull harder. Is seems hung up at the bottom. Does the oil line have to be lined up inside with a friction fit?
2015 Viper MTX
Oil drained
Exhaust removed
Frame brace removed
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Your fighting the magnets in the flywheel. It take quite a bit of “pull”. Likewise, watch your fingers when reinstalling.
Northern
- Nov 18, 2015
- Whitehorse YK
- 08 Nytro
08 Phazer
Thank you. That makes sense as it feels like something is pulling.
I will pull harder in the morning
Northern
- Nov 18, 2015
- Whitehorse YK
- 08 Nytro
08 Phazer
Magnets are pretty strong.
Stator is out. As predicted there is part of a tooth missing from the starter reduction gear and the stator is chewed up.
Ouch!
- 26K
