This was on another post but I thought I'd start a new one just for this problem. Here are the symtoms of this;
No action at the starter at all, nothing, acts like a bad ign. switch
The fuel pump does not come on when the key is turned
The starter relay may OR maynot check as normal ( this really threw me)
Code 43 on the dash, again sometimes not always.
The Fuel pump relay does click on and then off the way it should, but no pump.
The fault;
Inside the main wiring harness running along the left upper frame above the belt, has 3 multiple grounding blocks in it, one is a test point if you can find it as they are all burried in the harness and taped quite well. The test one is a small flat plug with 4 black wires and is above the driven clutch inside the harness. The second is under the water resevoirs, taped in the harness and hard to find, once you find it itès a great test spot to verify if you get all the grounds.
The 3rd, and my trouble is just ahead of the driven clutch, also in the harness and has 7 black wires in it, one 2 sizes lager then the rest. This was burnt and was no longer passing ground from all the components that are feed into it, which includes the fuel pump. I cut the plug out totally, slodered all 7 wires together , greesed the solder to prevent corrosion and then retaped the harness. If you feel along the harness the grounding pionts can be found and will need to be untaped to get access, but once you are there it is a great spot to start trouble shooting you electriacal trouble.
Hopefully no one will get stranded like I did and this post will solve somebody's trouble the way another post on here did for me. Thanks for all the responses regarding my posts.
I can't seem to down size a couple pics I wanted to post, so if anyone has this trouble in the future, PM me and I will be glad to Email them to you.
