- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
June 4 2006
Thundervalley Drag Way
The track was very very slick. It was "Corvette Day" and test & tune. There was maybe 12-18 Corvette's there and then 6-7 other test and tune vehicles and only one other car with slicks. They didn't prep the track like a normal race event (didn't put down as much VHT) so the track was extremely slick off the start.
Run 1: Ulmer Racing Stage 2 Apex
RT: .279
60': 1.673
660: 7.159
MPH: 96.677
1/4: 11.323
MPH: 115.483
Run 2: Ulmer Racing Stage 2 Attak
Attak weight settings & helix with Apex Stage 2 primary spring to lower engagement further to try to reduce the spinning.
RT: .047
60': 1.934
660: 7.710
MPH: 96.501
1/4: 11.857
MPH: 116.210
Run 3: Ulmer Racing Stage 2 Attak (same clutching as Run 2)
Softened up the rear suspension spring trying to get some transfer
RT: .031
60': 1.812
660: 7.304
MPH: 97.306
1/4: 11.438
MPH: 116.326
Run 4: Ulmer Racing Stage 2 Attak (same settings as Run 3)
Raced against a Z06 Corvette & whooped him by almost 2 seconds!!
RT: .044
60': 1.764
660: 7.253
MPH: 96.930
1/4: 11.400
MPH: 116.050
Run 5: Ulmer Racing Stage 2 Attak (same clutch & suspension settings as Run 2)
Leaned out the Air/Fuel Ratio at WOT
RT: .060
60': 1.789
660: 7.263
MPH: 98.252
1/4: 11.352
MPH: 117.754
Nice gain with the leaned out Air/Fuel ratio!! 1.3 mph gain in the 1/8 mile and a .048 second and 1.7 mph gain in the 1/4 mile
Run 6:Ulmer Racing Stage 2 Attak (same clutching & suspension settings as Run 2)
Ulmer Racing belt
RT: .190
60': 1.820
660: 7.331
MPH: 97.951
1/4: 11.435
MPH: 117.205
The belt was too aggressive resulting in more spin and a slower 60' time. Still had better MPH in the 1/8 & 1/4 mile than 8DN belt.
Run 7: Ulmer Racing Stage 2 Attak (Same clutching & suspension settings as Run 2)
Same setup as Run 5
RT: -.022 (redlight)
60': 1.806
660: 7.289
MPH: 98.575
1/4: 11.374
MPH: 117.686
All in all traction sucked but we made some gains in leaning out the fuel mixture and learned some things.
The temp ranged from 81*F to 83*F in the 3 hours we ran. The humidity ranged from 53% to 58% and corrected altitude from 4081 feet to 4720 feet.
RT: .279
60': 1.673
660: 7.159
MPH: 96.677
1/4: 11.323
MPH: 115.483
RT: .047
60': 1.934
660: 7.710
MPH: 96.501
1/4: 11.857
MPH: 116.210
RT: .031
60': 1.812
660: 7.304
MPH: 97.306
1/4: 11.438
MPH: 116.326
RT: .044
60': 1.764
660: 7.253
MPH: 96.930
1/4: 11.400
MPH: 116.050
RT: .060
60': 1.789
660: 7.263
MPH: 98.252
1/4: 11.352
MPH: 117.754
Ulmer Racing belt
RT: .190
60': 1.820
660: 7.331
MPH: 97.951
1/4: 11.435
MPH: 117.205
Same setup as Run 5
60': 1.806
660: 7.289
MPH: 98.575
1/4: 11.374
MPH: 117.686
- Apr 14, 2003
- Hessel, Michigan
Allen, just think,.........I have to deal with this traction issue everytime I go to the track cause of the gravel dust.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Terry, I pitty you big time!!! I was as soft as I could set everything pretty much!! It was pretty consistant though, but still sucked! Next time out if it's this slick I'm going to try some different combinations and moving the weight around on the Super Tips.
Edit: Added in some weather information from our weather station while we were running.
Buster696
Well guys had a good time last night at NYIRP. Wednesday night is Import Night, but had some larger than normal attendance due to the big IHRA event this week, a lot of guys trying to get ready for the weekend.
60’ times were average at most, and had a few runs in the 8.8’s and a couple in the 8.7’s when we went down the middle of the track. There is more here just have to sneak up on it…
Best ET of the night was 8.784 at 150.57... (best MPH for the night was 150.8)
--Buster696--
--Buster696--
- Apr 14, 2003
- Hessel, Michigan
Awesome Mikey!!!
Wow Mike did you pull the skirt up,lol
Nice Job
Nice Job
Buster696
Ryan,
Nope, still have the skirt on...
(But, it will be coming off soon, stay tuned...)
--Buster696--
--Buster696--
hlmrx1
Well, managed to get out for another weekend, weather was good, other than headwinds all weekend. Managed to pull off a couple of runs close to the 10’s, a 10.02 and a 10.06. Ran my fastest speed ever, 131mph rounded off, I’ll post the results when I get a chance, too busy with other stuff right now. Made it to round two on Sunday and ran a 10.18 on a 10.30 dial on low boost. Everyone was starting to break out and both I and my opponent broke out on that round, only he broke out less than I did. It was all in the reaction time again!!!!
Blew two front wheels on different runs, first one, I was out of the groove quite a bit and there’s a cement slab that sits at the least a quarter inch higher than the asphalt and a chunk of the front ski wheel blew off when I ran over that. Didn’t really notice until I slowed down and the wheel stopped spinning and just dragging on that spot. It just made it a little harder to turn around. The second time was a couple of runs later guess the back wheel on the same side had taken a pretty good hit too and it just disintegrated, and I didn’t even notice it until I let off the throttle and the sled seemed a bit snaky, I looked at the left ski and everything was in tack, then looked at the right ski and all there was, was bearings left. Next race is on the 24th and 25th. Safe grad on the 24th, not sure on how much sleep I’ll be getting so I don’t expect to come out on top!!!!
- Apr 14, 2003
- Hessel, Michigan
Ryan (pro116) and myself will be doing a little clutching tomorrow night, and hopefully the rain stays away.
- Apr 14, 2003
- Hessel, Michigan
I have to thank Ryan (pro116) for coming down and helping out with clutching and towing the Attak back to the pits. Thanks Ryan!
Friday Test & Tune 6-16-06
Temp at the track was 90 degrees with 44% humidity. Dropped to 77 degrees with 60% humidity. Wind was right down the track at us with 30+mph. Tried some different clutching combinations.
1st run - Tried a supertip combo with a pink spring.
1.615 60ft - 7.098 1/8 @ 95.792mph - 11.399 1/4 @ 111.096mph
2nd run - lightened weights to get correct rpm
1.599 60ft - 7.073 1/8 @ 95.566mph - 11.367 1/4 @ 111.200mph
3rd run - put in Attak stock clutching
1.603 60ft - 7.102 1/8 @ 95.556mph - 11.390 1/4 @ 111.404mph
4th run - put in my super tip clutching that I used on trail with nitrous
1.616 60ft - 6.570 1/8 @ 108.906mph - 10.355 1/4 @ 124.262mph
over 1 second difference with the nitrous
5th run - Ryan took the sled down with the same clutch setup.
1.599 60ft - 6.806 1/8 @ 102.141mph - 10.864 1/4 @ 116.946mph
Ryan's run proved to me that 40-50 lbs. really plays an effect on time and speed. Also noticed that the fuel injection does not seem to be adjusting to hot weather. Had some bogging issues off of the line.
- Apr 14, 2003
- Hessel, Michigan
Saturday 6/17/06 Super Stock Outlaw & Jet night
Same temps and humidity as last post. In a nut shell, TOO HOT!!!
1st time run - same clutch setup as last post when Ryan ran the 10.86 (lane 1)
1.593 60ft - 7.079 1/8 @ 94.480mph - 11.390 1/4 @ 110.784mph
wind speed was 30 + again right in our faces
2nd time run - same as before (lane 2)
1.591 60ft - 7.105 1/8 @ 95.631mph - 11.425 1/4 @ 110.016mph
round 1 - lane 1, dial-in was 11.44
1.614 60ft - 7.111 1/8 @ 94.224mph - 11.670 1/4 @ 87.635mph
On the brakes hard, won round 1
round 2 - lane 1, dial-in was 11.42
1.587 60 ft - 7.055 1/8 @ 96.237mph - 11.434 1/4 @ 97.537mph
on the brakes, won round 2
round 3 - lane 1, dial-in was 11.33 (raced my good buddy Ken Ziats with his mid 9 crank shop 1000)
1.583 60ft - 7.035 1/8 @ 96.576mph - 11.285 1/4 @ 112.817mph
Ken ridlighted by -.020, so I was able to run the sled out the back door, and not worry about breaking out. Won round 3
round 4 - lane 1, dial-in was 11.29 but the threat of storms were coming
1.594 60ft - 7.089 1/8 @ 95.679mph - 11.398 1/4 @ 110.915mph
Won round 4 due to the other guy redlighting when his slipper clutch failed and launched the bike forward.
With the last 2 getting ready for the final round, the rain and wind showed up, so the race was cancelled. Good news is I went to the final round, made some good money, and bumped my points up to 1st place I believe, but will post when point standings are updated.
Good Father's Day weekend for me!
WIR
Terry thank's for the ride.Now get that thing geared down,lol
- Sauk Prairie, WI
- www.ty4stroke.com
Re: WIR
I agree Ryan. Terry, I mentioned that on the phone the other night. No way you can pull that gearing with your weight. Good luck bro...BBY
pro116 said:Terry thank's for the ride.Now get that thing geared down,lol
monker
Made it out on Saturday for test and tune. Not much to report from that. Times were in the 9.9s and 9.8s. Not too bad I guess for the number of cars and high temps.
My racing in Sunday was cut short. Made 2 trial runs, then found part of my track coming apart. Looks like I may be taking another week off until I can get a new one. Hopefully I'll be back in business for the shootout in July.
