Well after the other issue (BLOWN MOTOR) I am getting my sled back with the turbo upgraded to 10#'s of boost should be running 230 to 240 HP. When it did blow up, that morning I lost reverse prior to it going down. (what a day)
I got it back a week and a half ago and did 300 miles of break in with it set at 6#'s of boost because the upgraded fuel pump did not work. But still no reverse. I rode those miles having to remember that I could not back up. The Dealer knew about it but forgot to put it on the work order so it was not fixed during the 4 wks it was there.
I pulled it and found it would click in my hand but the gear did not move. They wanted me to bring it back but its 2-1/2 hours away so I talked them into getting one. I took the sled back on Saturday They got the new pump in and did find the actuator to be bad so it was a warranty repair this time.
They are working on re clutching cause it bangs off the rev limiter but should be done tomorrow. I will let you all know what a 550 lb machine with 240 hp feels like and shoot some video running against my Pro r 800 should just burry the polaris (it already has at 6#'s)
