![](/styles/vip.gif)
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I've now developed a kit that will reinforce the front skid mounting area of the tunnel. There have been reports of tunnels cracking, severely mangled tunnels due to cross shaft shears, and egged holes due to bolts coming loose. This kit will help address all of these issues. It can be used to reinforce and preserve a good tunnel or used as a repair option for a tunnel already compromised. The outer plate is large enough that it should hide any weld repairs, dents, tears ect to the tunnel and provide a clean finish.
swampcat
Nice to have someone like you designing things like this, to help save our precious riding time.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Travis, does the RR have a extra plate here or is it same on tunnel as our winders?
Any chance a smaller plate to fit within the impression would be enough? With my red tunnel I think this might be abit large looking.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
To use the large plate I have a shim plate that fits in the pocket as shown. I have been thinking of just offering the small plate for extra reinforcement on a non compromised tunnel. This would essentially be saver, and then the large plate would be more for those that have a damaged tunnel as a form of repair if tunnel.
I'm thinking I would just make the small plates out of steel and powdercoat them black.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Why wouldn't you stay with aluminum Travis?
This plate spreads the force over a much larger area, so would aluminum be sufficient?
MS
MS
snowfever27
- Jan 7, 2015
- Vermont
- 2015 Arctic Cat XF7000
2009 Yamaha Nytro XTX (sold)
2007 Yamaha Phazer FX (sold)
2005 Ski-Doo MZX 800 Adrenaline (sold)
2003 Arctic Cat F7 EFI (sold)
2007 Yamaha Attack
2009 Polaris 600 Dragon SP
- Vermont
Travis, I would definitely buy the smaller plate in aluminum from you. Offer it unpainted as well as powder coated. There’s a lot of bare aluminum tunnels out there (mine is unpainted). The prototypes look great!!
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
MS
The larger "repair plate" would definitely stay aluminum.
Since I don't have to form the small "saver" plate I could use a 6000 series aluminum instead of a softer series. Strength on a 6000 series is almost comparable to steel. Ok, you guys talked me into sticking with aluminum for the saver plate as well.
![Div20 ;)! ;)!](/styles/default/xenforo/smilies/div20.gif)
As for finish I will offer it natural and powdercoated black.
YamaSpark
- Sep 21, 2017
- Greenfield, Minnesota
- 2016 SR VIPER S-TX 137 DX
Count me in for a pair of black "saver" plates!
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Love the smaller aluminum unit! Looks great!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Travis.....
With the smaller saver plate(alum) will we then need longer bolts then stock?
If A guy was to use the RR shaft/bolts ect.....are they the correct length bolts for this save plate?
How bout a red powdercoat?![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thnx
Dan
Thnx
Dan
HaHa. Dan, i didn't want to be the first to ask for colors so thank you! Travis, I'll take a set in "Yammi Blue"! And will the cross shaft be powder coated as well?
Joseph Levandoski
- Oct 19, 2016
- Ellington, CT
- 2019 Yamaha Sidewinder X-TX LE 141
Definitely interested in the smaller plate powder-coated in black (and it wouldn't corrode if made from aluminum). As someone who rides fairly hard, this would be welcomed in supporting any hard loads the suspension sees.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Yes the cross shaft sleeve will be powdercoated finish.
As for the plates, I will look into colors. Maybe on the first go around I can offer select colors if I get enough orders. They are such small pieces, so set up fee for switching colors make make it a bit expensive if I don't have a large quantity to do.
I will add a poll to the thread to track the color interest.
hman4
- Sep 22, 2014
- 2010 Apex, 2002srx, 2000 srx
I'll take a set in red!
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Travis.....
Thnx
Dan
I need to work through the bolt lengths yet to decide if longer bolts are needed. Don't think there will be any issues for guys that opt for my cross shaft saver beings the end point of bolt is not critical. If using the RR shaft I will have to check to see if the bolt end point being .125 inches shorter falls right where the collar meets.
- 39K
