DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Mine sure doesn't look that pretty anymore after sustaining 3 major hits lolAlbeit on a Cat.... View attachment 136315
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
It took awhile to clean out all the fibers....geesh.Mine sure doesn't look that pretty anymore after sustaining 3 major hits lol
I got left panel inside here, got here nice and clean but took time!
I knew this protector was gonna be a smart buy
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I knew this protector was gonna be a smart buy![]()
An ounce of prevention. Especially when things get turned up.....
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
It's doing it's job then. Has it held it's form after the hits?Mine sure doesn't look that pretty anymore after sustaining 3 major hits lol
DMCTurbo
- Nov 12, 2005
For the most part, I took it off and pounded her flat where it took a big hit at 120+It's doing it's job then. Has it held it's form after the hits?
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
So you've been customizing it? LOL
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Where abouts? Mine did not hurt a thing...it slapped across that front small piece alot, saving that plastic. Typically top and bottom dont get pounded but the ends do(front top and rear bottom) as that is where the belts whip off their arc.For the most part, I took it off and pounded her flat where it took a big hit at 120+
Dan
DMCTurbo
- Nov 12, 2005
Dan[/QUOTE
Halfway, directly in the centre of the clutches...
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
WOW, Interesting......so with the foam under it, it bend downward eh?
DMCTurbo
- Nov 12, 2005
Yup bent downward, woulda been a huge hole there had I not installed the protector.WOW, Interesting......so with the foam under it, it bend downward eh?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Seems like odd place to take a whack.....but when a belt blows it becomes a projectile, likely never the same from one to the next....I just hope its a rare occurrence.Yup bent downward, woulda been a huge hole there had I not installed the protector.
nadekeys
- Oct 20, 2009
- Green Bay, WI
- 2017 Sidewinder LTX LE
2009 Apex LTX GT
2008 Nytro MTX Turbo
I blew a belt on my turbo nytro this past weekend, sent a chunk clear through the aluminum plate here right into my shin.... This was the only damage. Threw a new belt on, bent the sharp edges on this hole back that looked like it was hit with a grenade launcher and good to go. Belts blowing can be really dangerous. This is the only time I've ever seen anything like this.
Sent from my SM-N950U using Tapatalk
nadekeys
- Oct 20, 2009
- Green Bay, WI
2009 Apex LTX GT
I needed a pliers and other tools to bend the pieces back in a bit , it isn't very thin aluminum!
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
For those that have my belly pan protectors that sustained a hit I'd like some pictures. I've yet to blow a belt on mine and would like to be able to monitor how the guards are holding up to different blows.
