17RTXSidewinderLE
- Nov 8, 2017
- 2017 Sidewinder RTX LE
So the other day I backed my sled into the trailer and shut it down all was well until the next morning . I started the sled up after sitting all night and it turned over slowly and was idling really low at 1000 rpms. I shut it down and pulled the belt , it burnt up backing into the trailer I guess ?
Anyway new belt on and idle corrected itself around 18-1900 until warmed up and then 1450-1500. Broke the belt in and all was good but after 50 miles when I come to a stop and I'm idling the sled has a light belt squeal . All stock no aftermarket belt adjuster . I'm used to the old Yamaha clutches with the three bolts on the back and shims to adjust the tightness ...what's the easiest way to adjust these new clutches ? New Belt is very tight and sits low in the secondary .
8JP belt just to clarify.
Sled seems to be working great just don't want to listen to the squeal every time I come to a crossing or stop to talk to a buddy.
