herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Well at least you have snow to ride on. This has been a lousy winter in New Hampshire this year. Mostly rain.
Pete
Pete
twiz28
- Nov 8, 2004
- New Brunswick, CAN
- 2017 Sidewinder BTX 1.75 Backcountry
2017 Sidewinder XTX 137
I spoke with Peter, it's an easy fix. You need a M10 100mm bolt with 1.25 thread preferably 10.9 grade and a 15 mm spacer to go in the web. Fastenal part # for the bolt is 11113978, this is where Peter is sourcing them. I'm thinking even a stack of washers would work for a spacer as long as the stack measures 15 mm, washer tolerances aren't exact so out of a box you could probably make a stack 15mm thick pretty easy.
sprintcat
- Jan 13, 2009
- Rumford Rhode Island
- Nytro xtx
Gooding going , get out and ride after that .lol
Mountaintech
Correct. Those are the specs for the 09 and up spindle. If you want to update the 8GL spindle (2008 short tracks) you will need a spacer 18.7mm thick with a bolt that is at least 105mm long.
sprintcat
- Jan 13, 2009
- Nytro xtx
Quick question for Peter
sprintcat
- Jan 13, 2009
- Nytro xtx
When setting the front suspension up with your kit, caster camber , should we be putting simulated weight on the sled ? I didn't see that in the directions. Just wondering because I am getting ready to go over my sled . PS. I put about 110 miles on the kit what a dream machine now
SteelerJim
- Dec 6, 2010
- Rockton, Pa
- 2011 Nytro XTX
Thank you to Peter at Mountaintech. I already have my updated hardware! Awesome job!
herndonp
- Nov 28, 2012
- Freedom,NH
Pete is good that way.
sprintcat
- Jan 13, 2009
- Nytro xtx
X2
- 29K
