jboar
I have an 05 rage and in the last 200 miles I blew three belts. I cleaned and inspected clutches made sure everything is set to stock. It does not seem to be slipping just overheating. any suggetions what to check?
superb
- Apr 10, 2004
- Ottawa, Ontario
- 2015 Viper turbo, 2013 Apex, 2012 Vector LTX, 2010 Vector LTX
Check the aluminum plate under your clutches. Sometimes they get bent up and the belt rubs on it.
jboar
Its not that the cords are letting go and the outside layer is coming off.superb said:Check the aluminum plate under your clutches. Sometimes they get bent up and the belt rubs on it.
lenman20
- Mar 20, 2007
- merrimack nh
- 2005 rs rage
Get your hands on a clutch allingnment tool. Check you motor mounts. Some thing is up. Maybe broke a spring
lenman20
- Mar 20, 2007
- merrimack nh
- 2005 rs rage
you should put your new belt in the dish washer. some times it help. in fact put your secondary in also and if you have a clutch tool put the primary in also. should be nice and clean. do this when the women are not around they wont like it.
MadMax
Somethig is waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaay wrong.. I put 8,000 miles on my factory belt before changing... MM
jboar
Everything was in the dishwasher belt, and both clutches, both dissassembled. Reassembled and blew another belt. The motor seems solid and jack shaft bearing is good. There is no performance loss just belts.
lenman20
- Mar 20, 2007
- merrimack nh
- 2005 rs rage
how does your belt sit in the secondary. are you sure you did not break a motor mount. something is out of alignment. how clean is the inside of the motor compartment is there sand or something. just throughing out stupid ideas good luck.
jboar
Just checked the motor mounts all good. Very clean under the hood there are no belt marks on the clutches to indicate slipping
lenman20
- Mar 20, 2007
- merrimack nh
- 2005 rs rage
hope you figure it out let us know when you do
lenman20
- Mar 20, 2007
- merrimack nh
- 2005 rs rage
maybe ask this question in engine & clutches
jboar
Is it possible that the secondary spring is to tight and in the deep powder when the sled is working hard the secondary isn't opening enough and straining the belt to the point of blowing apart? All three belts were riding in temperatures right around 0degrees celsius(32 f) and deep soft snow with long stretches of wide open throttle, let off for a second and open it up again.
MadMax
That is "NOT" ideal conditions......... That is pure H%^%$#ll on belts... MM.
jboar
I know that but I am the only one blowing belts. Riding with a group of 8 and I went through 3 belts and nobody else had to change one
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
jboar said:Is it possible that the secondary spring is to tight and in the deep powder when the sled is working hard the secondary isn't opening enough and straining the belt to the point of blowing apart? All three belts were riding in temperatures right around 0degrees celsius(32 f) and deep soft snow with long stretches of wide open throttle, let off for a second and open it up again.
Heat is a killer for sure, and what you are saying above, sure generates a lot!
Just saying, but your sled wasn't really designed for that type of riding either.
Curious. are they OEM belts of aftermarket?
