KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I bought some 4oz aluminum bottles from the following company for about $1.60 each. They have a lot of different options including glass.
4 oz (120 ml) Aluminum Bottle with Black Cap
Our Brushed Aluminum 4oz Bottle is as tasteful as it is durable. Use for food, beverage, healthcare, or body care products. Great savings for volume orders.www.specialtybottle.com
What kind of seal do they have on the cap? I found the seal on some of these cheap flasks don't seal well and leak, wonder if the plastic cap will be a problem too and leak or get eaten up depending on the plastic used.
Have you used them yet in the trunk of the machine with Boostane in them for any miles?
WarriorDan
- Oct 30, 2003
- Bloomfield Hills, MI
- 2022 LT-X GT EPS
I have not received the bottles yet but I am assuming that the cap insert is just typical coated paper, but that is just a guess. I was thinking that I might have to cut a piece of silicone or something or buy a nylon washer or something to replace it worse case. I am not thinking of storing Boostane in the bottles long term but more like using them for a week or so and then emptying them for longer storage. I tried to see if Boostane is reactive to aluminum but I did not find anything that said it was a problem, thus I ordered and should be getting them any day now.
The 5 oz flasks I am using are all metal and never leaked all last season.What kind of seal do they have on the cap? I found the seal on some of these cheap flasks don't seal well and leak, wonder if the plastic cap will be a problem too and leak or get eaten up depending on the plastic used.
Fords4life
- Dec 7, 2021
- South Dakota
Bought a couple wisky flasks from amazon a couple years ago and the plastic type material for a gasket swelled and leaked so i cut cork automotive sheet gasket material as replacements, holds the boostane with out issue.
Turboflash
- Mar 18, 2019
- Southern MN
I'd use that flask for something different lol!I don't use Boostane Professional I have been using Boostane Marine and carry it in 5oz flasks for trail fuel stops...LOL...I like to be different.
Turboflash
- Mar 18, 2019
- Southern MN
I use Boostane Profssional. I carry 2 oz glass bottles in my pocket. They are thick-walled. Never had any issues with them. 2 oz will treat 8 gals of 91 up to 95 octane "supposedly." Been working.I wish I could have found something like that in 2oz. I use plastic, and left some boostane in it. You can see the plastic deteriorating within the plastic container.
So, IMHO, plastic can be used for day trips, etc. just wouldn't leave it in there for any great length of time.
Nice one, Bob!
10PCS 2 oz Small Clear Glass Bottles(60ml)With 2 Stainless Steel Funnels&32 Chalkboard Labels,Boston Round Shot Bottles with Caps,Perfect for Party Favors,Essential Oils,Juice,Whiskey,NO Leakage https://a.co/d/aBlxBZ6
tsiceman
- Jan 31, 2006
- Fishers, In
- Winder ltx le
Our group is using 4 oz acetone bottles from Walmart. One season of use so far, no leaks. The bottles are staining brown a little bit.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I just wrap the 32oz can in a towel and put it in my saddle bag.
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Been using a 16oz SeaFoam bottle wrapped in a towel
A glass "Nip" bottle would be perfect. 50ml (1.7 oz.). You know they won't leak and as an added benefit you can see exactly how much you have used if you only take a half tank fill up
stone88
Ive been using left over lucas octane bottles for mine but I like the Idea of those 5oz aluminum bottles.
Turboflash
- Mar 18, 2019
- Southern MN
10PCS 2 oz Small Clear Glass Bottles(60ml)With 2 Stainless Steel Funnels&32 Chalkboard Labels,Boston Round Shot Bottles with Caps,Perfect for Party Favors,Essential Oils,Juice,Whiskey,NO Leakage https://a.co/d/9n573TqA glass "Nip" bottle would be perfect. 50ml (1.7 oz.). You know they won't leak and as an added benefit you can see exactly how much you have used if you only take a half tank fill up
Haha. Exactly like the ones I purchased. I'm not a "Nip" drinker anyway!10PCS 2 oz Small Clear Glass Bottles(60ml)With 2 Stainless Steel Funnels&32 Chalkboard Labels,Boston Round Shot Bottles with Caps,Perfect for Party Favors,Essential Oils,Juice,Whiskey,NO Leakage https://a.co/d/9n573Tq
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Exactly what i found to be good.. I buy a new can every year and dump into the truck and fill with Boostane.. I put it inside a old leather mitten. PerfectBeen using a 16oz SeaFoam bottle wrapped in a towel
