Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I get it...it's more of a retainer.Just a safety measure since I am using the yamaha return nipple and grommet.
No issues at all but just piece of mind when running thru the trail junk...
Thanks, Tim
Doc Harley
- Oct 17, 2016
- Here & there
Turboflash, I found the pump...walbro GSS342.
If there's something more beneficial let me know.
I'm not doing this tomorrow, but I'll prepare the harness, pump, return line.
Thank you!
Thank you!
Doc Harley
- Oct 17, 2016
- Here & there
Harness ordered!
Kenneth Rogers
- Jan 23, 2019
- Fort McMurray, Alberta
- 2021 Sidewinder SRX LE
2018 sidewinder xtx-se 137”
1997 Vmax 4 800 shorty
1996 Vmax 4 800 shorty
1995 Vmax 4 Improver
1994 Vmax 4 St
1993 Vmax 4 800
1990 Phazer
1989 Bravo
1980 SRX 440
Return fuel line not re-routed?Any questions or concerns?View attachment 173931
Doc Harley
- Oct 17, 2016
- Here & there
I have parts, just haven't did it yet. So, I'll do the harness, re-route & pump at the same time.Return fuel line not re-routed?
Turboflash
- Mar 18, 2019
- Southern MN
TD, Hurricane, and PEFI all sell pump upgrade kits. IMO, if you want the best, get PEFI. ( https://precisionefi.com/en-us/collections/9000-series/products/fuel-upgrade-kit). It's the most expensive one but most say no one has better quality hardware than PEFI. Others work fine too.Turboflash, I found the pump...walbro GSS342.
Thank you!
I think most say a fuel pump upgrade is a very good idea with bigger tunes. For sure you want to make sure engine doesn't get starved for fuel. IMO, the best advantage of a complete fuel pump upgrade kit is the fact that return fuel empties into the slipper that holds the fuel pump (and suction ports) making sure it's always full, and not cavitation even on rough trail and even under low fuel conditions.
Doc Harley
- Oct 17, 2016
- Here & there
I understand, as I watched Pefi's video this morning. We are doing this ourselves when we drill the plate for the return and sending fuel back directly to the pump. And now (I forgot) the need for harness.TD, Hurricane, and PEFI all sell pump upgrade kits. IMO, if you want the best, get PEFI. ( https://precisionefi.com/en-us/collections/9000-series/products/fuel-upgrade-kit). It's the most expensive one but most say no one has better quality hardware than PEFI. Others work fine too.
Lots of dragy testing will dictate my next move. Which would be a bigger pump and tune.
