REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
TorchRed is permanent. The only way I’ve ever gotten something apart after using red was to heat it up with a touch
Turboflash
- Mar 18, 2019
- Southern MN
The ones I've seen with red after years of service were still tight and solid. I wonder how well the factory thoroughly cleaned/degreased both the screws and the roller axle prior to assembling? I'm sure both has oil on them as received into inventory.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
maybe they put left over anti seize from the drive axle bearing on them?The ones I've seen with red after years of service were still tight and solid. I wonder how well the factory thoroughly cleaned/degreased both the screws and the roller axle prior to assembling? I'm sure both has oil on them as received into inventory.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Did you removed yours yet to re-apply anti seize? If so how tight was the screw from factory?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
??Did you removed yours yet to re-apply anti seize? If so how tight was the screw from factory?
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
I mean you had yours welded. So you didn't remove the screw to see if the factory loctite was any good?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I removed it and had it welded.. I did not loosen screws but I did try to tighten them and they were solid. I figured why loosen them and break the thread locker, as I was getting it welded.I mean you had yours welded. So you didn't remove the screw to see if the factory loctite was any good?
Turboflash
- Mar 18, 2019
- Southern MN
