number1kyster
I'm at 5,000 miles on my original chain. I'm out of adjustment on my chain tensioner bolt with the spacer. Can I remove the spacer for more adjustment, or is it time for a new chain?
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
I would say new chain. I changed mine when I was at that point.
Maybe check out some different ratios at the same time.
I assume you are running the stock 21-41?
I am changing my 21-41 to a 24-50.
Turboflash
- Mar 18, 2019
- Southern MN
IMO, new chain (& check gears maybe). The last thing you need is chain failure!
number1kyster
Yes, I want to try 24/50. I think it's better suited for VT.I would say new chain. I changed mine when I was at that point.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
I would also say 'new chain'.
As the tensioner begins to bottom out, and there is no more adjustment - the angle on the return chain gets to be pretty crazy.
MS
MS
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
24/50 will be a disappointment. I tried it on my sled and it was slower and less fun to ride. Maybe it would be good if you have a 1.75 inch track.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I would agree if high speed running is your thing. Trails here are more of the twisty/ throttle on/off variety.24/50 will be a disappointment. I tried it on my sled and it was slower and less fun to ride. Maybe it would be good if you have a 1.75 inch track.
I have ridden multiple T-cats and ZR9000's with 24-50 gearing and they seem more responsive than the 21-41 gearing in my Sidewinder.
I know the comparison is not apples to apple's with the Team clutch starting in a higher gear due to the bearing in the primary.
I think also the fact that the Team set up with the auto belt tensioner making that belt banjo string tight contributes to the responsiveness.
Either way, I am going to try the 24-50 in my new S/W . I know what the 21-41 feels like and can go back if needed.
Big_Phil
- Feb 5, 2014
- Sidewinder RTX LE
Maybe it’s the clutching setup on yours that is different or the cat had better traction. 24/50 setups are usually cheap enough to try so why not. I ride super tight trails and noticed the 24-50 had less snap, didn’t pull the skis as easy, etc. high speed trails wasn’t much difference as both ratios can cruise at 100mph+ no problem.I would agree if high speed running is your thing. Trails here are more of the twisty/ throttle on/off variety.
Turboflash
- Mar 18, 2019
- Southern MN
IMO, turbos like load; more load = faster spooling. Less load (lower gearing) = slower spool. TCats came with 24/50 (yes, Team clutching) but as per Big_Phil, even in tighter trail systems, they pull harder corner to corner with higher gearing (22/41? 21/38?) and 60 & 330 ft times are faster (on Dragy) (assuming traction). IMO, Cat used 24/50 to limit top speed (makes lawyers less nervous) and extend belt life. From the start (2017) Winders had better MPH than TCats due to higher gearing. But with 24/50 TCats just don't pull hard, they just spin.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Here’s my thoughts with that.
For sure, new chain and top gear.
Check your internal wear on that post/nub, whereas the stock 21 top gear allows that chain to hit that. It happened on mine (2017) during the first 1100 - 1200 miles, and I caught it during my second chain case oil change and inspection.
At that point I had talked to my dealer concerning that, and that is a common problem for vipers before the winders came out. So I added a 22T and a light EcoTrail tune and tested with both gears, 21 and 22.
What I found was that extra tooth with it’s larger diameter kept the chain away from that internal post/nub, and the 22T gave my sled set up, a smoother faster pull throughout!
I ride pretty hard and fast on both medium and Big trails.
So good luck with your upcoming gearing choices!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
What he said !!!!! 22 Top.What I found was that extra tooth with it’s larger diameter kept the chain away from that internal post/nub, and the 22T gave my sled set up, a smoother faster pull throughout!
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I think they used the lower gearing to compensate for the higher starting ratio the Team primary has vs. a primary clutch without auto-tensioner. It keeps them from burning belts down low/ low speed maneuvering.IMO, Cat used 24/50 to limit top speed (makes lawyers less nervous) and extend belt life.
Either way, I am gong to give it a shot with my new 1.5 rip saw and will see what happens.
The ones I ride with made the track change away from the 1 inch and are well studded. Spinning is not really an issue.But with 24/50 TCats just don't pull hard, they just spin.
number1kyster
I have picked up a set of 24/50. I'll pick up a 22T top gear to have on the shelf in case I don't like 24/50.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Replaced my chain at around 9000 miles.
Installed 22 tooth top gear at that time and really like it. Pulls harder out of the hole but I am running ss header tunes which comes alive instantly and has huge power for trail.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
I should point out that since that Ecotrail tune, I updated to the MS16 tunes with same gearing for the past 4 seasons.Here’s my thoughts with that.
Replaced my chain after 5500 miles because it was stretched to the point of no adjustment left also, and I replace my T22 almost yearly. $24 last season...
