scooterwj
- Dec 4, 2008
- Hell, Michigan
- 2018 SW
I opened up the chaincase on my SW to check the 2 screws on the tension roller. They were tight and had green locktite on them. I adjusted my tension to finger tight then 1.5 turns out.... Check out the video, chain seems really loose. I did the same thing on an '18 viper a couple weeks ago and the chain was much tighter. Is this correct? Should I loosen the tensioner on the viper? Finger tight is so subjective I think...
Also, check out the pictures from when I removed the reverse actuator/detent/etc. It looks like it wasn't installed correctly when I compare this to what the service manual shows. Look where the extension is in relation to the detent block. I understand the process to put this back together, it just seems like it wasn't done correctly at the dealer... Am I right about that?
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
You are absolutely right!
What a joke :-(.
What a joke :-(.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Exactly why for about a year now most of us have talked about ONE TURN OUT only. I never ran mine with 1.5 turns. Even 1 turn out is looser then I liked, but seems fine.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
I ran my sr viper and sidewinder 1 turn out no issues and 2 other winders also same outcome.
By any sled standards that is too loose...I would go finger tight then back it off 1/2 turn.
Pstn head
That's too loose and that reverse detent is totally wrong.
- 10K
- 14K
