Clutch offset
Has a final clutch offset number been agreed on ?
Unless all you do is top speed runs at full shift, doesn’t matter as much as having a proper setup with springs and weights. Belts should last several thousand miles, and if they aren’t, you have an issue with your setup.
Offset varies from sled to sled. Pm me if you want help with proper offset process
